Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Michigan Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: just another truck
  #1 (permalink)
Old 03-08-2006, 10:22 PM
bluneon bluneon is offline
Garage is empty, add now
bluneon is starting off with a positive reputation.
my call out for help with truck; stumped near detroit
i'm stumped as to what's wrong with my truck.
it's an 89 f150 with the 302 EFI AOD 2wd. XLT lariat
i'm near detroit so if anyone can offer a hand and/or advise come take a look at my truck that would be great. it just won't start. just cranks and crank until it finally leaves me with a dead battery.
thanks.
  #2 (permalink)
Old 03-09-2006, 03:19 PM
gman41364 gman41364 is offline
gman41364 is starting off with a positive reputation.
have you pulled a plug to make sure you have A) spark B) fuel getting to the cylinders yet?
  #3 (permalink)
Old 03-09-2006, 04:20 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.
A. wonder if ignition wires are damp and shorting out??? B. Fuel filter/fuel pump??
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #4 (permalink)
Old 03-11-2006, 09:35 AM
Ervin Ervin is offline
Ervin is starting off with a positive reputation.
Hi, I was just surffing around and saw your post. Pull the cap and see if you dist. is turning. Could be a timing chain. Mine just did this. Erv
  #5 (permalink)
Old 03-12-2006, 07:23 PM
ok. problem fixed. i finally got time to replace the plugs and wires, i also replaced the dist. cap.
the truck started right up. i went to hook up the scanner to the plug under the hood and then the truck cut out.
turns out one of the fuel pump relay wires was extremely corroded that the terminal end broke off, hence cutting off fuel to the motor when i was handling the wires in that area for the scanner.
whether this was the original problem in the begining, i wouldn't know. but now i gotta run to the store and grab a terminal so i can hook up the fuel relay back on.
and here i was blowing my nonstart problem out of proportion with the TFI harness and module and the distributor...
thanks, guys.
  #6 (permalink)
Old 03-13-2006, 04:49 AM
Jimjdb1's Avatar
Jimjdb1 Jimjdb1 is offline
Jimjdb1 is starting off with a positive reputation.
bluneon:
Glad to hear you got her fixed. Hope everything stays cool on your end.
BTW: welcome to FTE. Hope you will hang around awhile and check us out. I think you will find out that we are a pretty good bunch of guys and gals.
Don't forget to join the chapter.
Jim
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
