General Automotive Discussion
Ford Engines Liter to Cubic inch conversion
Old 03-08-2006, 10:01 PM
dlwhitehead65's Avatar
dlwhitehead65
dlwhitehead65 is offline
Looking at buying a newer or new ford Pickup. These Liter engine sizes are confusing. My 94 F250 has a 5.8ltr 351 in it. Can anyone tell me what size the 5.0, 5.4 etc motor sizes are. The salesman at the ford place said that the 5.4 was a 351, what gives???
Old 03-08-2006, 10:04 PM
pfogle's Avatar
pfogle
pfogle is offline
He's wrong, the 5.3 is 330 CI.
Old 03-08-2006, 10:07 PM
okst1's Avatar
okst1
okst1 is offline
1 cubic inches = 0.016387064 liters
Old 03-08-2006, 10:09 PM
jroehl's Avatar
jroehl
jroehl is offline
You mean the 5.4 is 330c.i. Also, 5.0L = 302c.i. 7.5L = 460c.i.
Most (all?) engines nowadays are primarily known by their metric displacement.
Jason
Old 03-08-2006, 10:10 PM
okst1's Avatar
okst1
okst1 is offline
5.4 liters X (1 cubic inch/0.016387064 liters) = 329.53 cubic inches or 330 cubic inches
Old 03-08-2006, 10:28 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
For a rough number, take the litres and multiply by 60.625. This will get you within 2ci of the common accepted displacement of that engine, as long as the manufacturer was somwhat honest on the size.
Old 03-08-2006, 10:33 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Some of the older metric/English designations are listed in the engine forum titles. Some of the designations were fudged just a little...
Old 03-09-2006, 12:29 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
"Beemer Nut" is offline
Litre engine size divided by 16.39 will yield cubic inch displacement.
cubic inches times 16.39 equals litres
1,000 cc's is equivalent to 61 cubic inches.
Displacement in cubic inches, bore squared X .7854 X stroke X number of cylinders.
Bore in mm's squared X .7854 X stroke in mm's X number of cylinders divided by 1,000,000 for litres.
.....=o&o>.....
Old 03-09-2006, 07:35 AM
Casey's Avatar
Casey
Casey is offline
Let's try this.
302 * 16.39 = 4949.78. That's almost 5,000 litres, that's a BIG engine!
Divide that by 1000 and you'll have litres. Your formula should be Cubic inches times 0.01639 equals litres.[/QUOTE]
Old 03-09-2006, 03:34 PM
"Beemer Nut"
Yup, way to big unless it's a aircraft engine, me make little boo boo, should of not added "litre" at the end.
.....=o&o>.....
Old 03-09-2006, 04:12 PM
4wd's Avatar
4wd
4wd is offline
SIMPLE! Do it in your head
Just take the liters times 61 will give you close enough to cubic inches.
example, my 6.8 liter V-10 is 415 cubic inches (6.8 times 61),
and my 4.6 liter Crown Vic is 281 cubic inches (4.6 times 61).
(Liters times 60, then liters times 1, and add together, and round up)
Old 03-09-2006, 10:24 PM
Torque1st's Avatar
Torque1st
Posting Legend
-Or you can avoid all of the confusion with varying conversion factors and just go here:
http://www.unitsconverter.net/
Enter the number you know under the units in the volume secton and click on the calculate button.
351 cubic inches = 5.751859464 liters
5.8 liters = 353.9377157494 cubic inches
5.4 liters = 329.5282181116 cubic inches
5.0 liters = 305.1187204737 cubic inches
Old 03-09-2006, 10:42 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
1 liter = 61.0237440947 cubic inches.
Old 03-09-2006, 11:03 PM
mikemic's Avatar
mikemic
mikemic is offline
Interestingly, the Ford 5.0 (302) V-8 was really a 4.9 ,but 5.0 sounded cooler. The true 4.9 L was the 300 I-6.
Old 03-10-2006, 12:05 AM
"Beemer Nut"
A mental thing, Rover in 95 had a 3.9 litre V-8, in 96 it was 4.0 litre and both engines had the same bore and stroke.
To use a chart to figure engine math or litres displacement isn't a thing a true gearhead would use, like a power outage in a store, checker can't do the math. Modern times are called progress, I question that.
.....=o&o>.....
Quick Reply: Ford Engines Liter to Cubic inch conversion
