Ford Engines Liter to Cubic inch conversion - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 03-08-2006, 11:01 PM
dlwhitehead65 dlwhitehead65 is offline
dlwhitehead65 is starting off with a positive reputation.
Looking at buying a newer or new ford Pickup. These Liter engine sizes are confusing. My 94 F250 has a 5.8ltr 351 in it. Can anyone tell me what size the 5.0, 5.4 etc motor sizes are. The salesman at the ford place said that the 5.4 was a 351, what gives???
Old 03-08-2006, 11:04 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
He's wrong, the 5.3 is 330 CI.
Old 03-08-2006, 11:07 PM
okst1 okst1 is offline
okst1 is starting off with a positive reputation.
1 cubic inches = 0.016387064 liters
Old 03-08-2006, 11:09 PM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
You mean the 5.4 is 330c.i. Also, 5.0L = 302c.i. 7.5L = 460c.i.
Most (all?) engines nowadays are primarily known by their metric displacement.
Jason
Old 03-08-2006, 11:10 PM
5.4 liters X (1 cubic inch/0.016387064 liters) = 329.53 cubic inches or 330 cubic inches
Old 03-08-2006, 11:28 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
For a rough number, take the litres and multiply by 60.625. This will get you within 2ci of the common accepted displacement of that engine, as long as the manufacturer was somwhat honest on the size.
Old 03-08-2006, 11:33 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Some of the older metric/English designations are listed in the engine forum titles. Some of the designations were fudged just a little...
Old 03-09-2006, 01:29 AM
"Beemer Nut" "Beemer Nut" is offline
"Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE.
Litre engine size divided by 16.39 will yield cubic inch displacement.
cubic inches times 16.39 equals litres
1,000 cc's is equivalent to 61 cubic inches.
Displacement in cubic inches, bore squared X .7854 X stroke X number of cylinders.
Bore in mm's squared X .7854 X stroke in mm's X number of cylinders divided by 1,000,000 for litres.
.....=o&o>.....
Old 03-09-2006, 08:35 AM
Casey Casey is offline
Casey is gaining momentum as a positive member of FTE.
Let's try this.
302 * 16.39 = 4949.78. That's almost 5,000 litres, that's a BIG engine!
Divide that by 1000 and you'll have litres. Your formula should be Cubic inches times 0.01639 equals litres.[/QUOTE]
Old 03-09-2006, 04:34 PM
Yup, way to big unless it's a aircraft engine, me make little boo boo, should of not added "litre" at the end.
.....=o&o>.....
Old 03-09-2006, 05:12 PM
4wd 4wd is offline
4wd is starting off with a positive reputation.
SIMPLE! Do it in your head
Just take the liters times 61 will give you close enough to cubic inches.
example, my 6.8 liter V-10 is 415 cubic inches (6.8 times 61),
and my 4.6 liter Crown Vic is 281 cubic inches (4.6 times 61).
(Liters times 60, then liters times 1, and add together, and round up)
Old 03-09-2006, 11:24 PM
Torque1st's Avatar
Posting Legend
-Or you can avoid all of the confusion with varying conversion factors and just go here:
http://www.unitsconverter.net/
Enter the number you know under the units in the volume secton and click on the calculate button.
351 cubic inches = 5.751859464 liters
5.8 liters = 353.9377157494 cubic inches
5.4 liters = 329.5282181116 cubic inches
5.0 liters = 305.1187204737 cubic inches
Old 03-09-2006, 11:42 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
1 liter = 61.0237440947 cubic inches.
Old 03-10-2006, 12:03 AM
mikemic mikemic is offline
mikemic is starting off with a positive reputation.
Interestingly, the Ford 5.0 (302) V-8 was really a 4.9 ,but 5.0 sounded cooler. The true 4.9 L was the 300 I-6.
Old 03-10-2006, 01:05 AM
A mental thing, Rover in 95 had a 3.9 litre V-8, in 96 it was 4.0 litre and both engines had the same bore and stroke.
To use a chart to figure engine math or litres displacement isn't a thing a true gearhead would use, like a power outage in a store, checker can't do the math. Modern times are called progress, I question that.
.....=o&o>.....
you know how 5.0 liter is 302, well whats a 4.6 and a 5.4 liter? Pastmaster Modular V8 (4.6L, 5.4L) 21 02-17-2016 06:56 PM
Engine tuners Christian_m__ Garage & Workshop 2 05-28-2015 08:52 AM
5.4 liter engine noise badfl97 2004 - 2008 F150 15 03-20-2012 02:50 AM
5.0 v8 vs 351 v8 vs 4.6 v8 vs 5.4 v8 parkland 1997 - 2003 F150 15 09-05-2011 12:09 PM
2001 ford location of sensor`s on 5.4 liter digdug442 1997 - 2003 F150 4 09-07-2009 12:08 PM
Tags
40, 46, 54, conversion, convert, converted, cubic, engin, engine, equals, ford, inch, inches, liter, litre
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
