What year of computer will interchange - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 03-08-2006, 04:57 PM
SShank42's Avatar
SShank42 SShank42 is offline
SShank42 is starting off with a positive reputation.
Like title asks. I have 1987 BII with 2.9 automatic. Found a computer from a 1986 BII. Will they interchange? Thanks
Old 03-08-2006, 06:36 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
If the '86 computer is from an auto, it should work just fine.
Old 03-09-2006, 08:42 PM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
If '86 and '87 years both had the A4LD auto transmission...
Not sure if the A4LD's used a speed sensor in the tranny for both cruise control and otherwise, though (?). My '87 5-speed has a speed sensor in the tranny specifically for the cruise control, if I remember right. I don't think it has anything to do with the engine computer *shrug*
Old 03-10-2006, 09:01 AM
SShank42's Avatar
I looked at a couple of parts stores on the net and my local store to see if the two years had the same part number. They do not. According to them it would be two different computers. The one that I got was from a 1986 a4ld BII. Not sure what to do. Do I try it even though the parts store have different numbers for the two years?
Old 03-10-2006, 09:24 AM
OSin86 OSin86 is offline
OSin86 is starting off with a positive reputation.
Quote:
Go to autozone.com and look up the wiring diagrams for both vehicles. If the pins and wires are all the same with the same sensors then you've got nothing to worry about.
Old 03-10-2006, 04:18 PM
SShank42's Avatar
Well got BII back. The torque not locking up was fixed with the new computer but now the engine does not perform like it should. My 87 computer has part# E7TF-12A650-BH1A, the 86 has part# E6TF-12A650-P2A. So I fixed one problem but caused another. At least I know what my original problem was.
Old 03-10-2006, 07:50 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
What preformance problems are you having. The part number looks like it's basically the same, just some possible programing changes which would only be minor since there were no significant changes between 86 & 87.
Old 03-11-2006, 08:25 AM
SShank42's Avatar
At cruising speed, steady throttle pressure everything ok. Excelerating it act like it is running out of gas. It will search then act like it is choking on itself then surge, so on, so on. Idle is okay. Took my original and put it back in, road tested, and the engine was back to normal and the torque would not lock up. So there is definately a programming issue. My original (87) had every pin in place on the computer, the 86 has 10 pins missing.
89 BII Bulkhead Electrical Connector tommyleea Bronco II 4 01-03-2011 09:03 AM
Water leaking inside BII when rains. dmkolb Bronco II 37 12-16-2009 02:22 AM
Bronco wheels on a BII dino360 Bronco II 1 01-13-2008 04:12 PM
Bronco II-Ranger parts interchangeable twisted limb Bronco II 5 11-01-2007 12:11 AM
drive shaft interchange 84mustang Bronco II 6 10-14-2004 06:11 PM
Tags
40, computer, computers, e7tf12a650bh1a, ford, honda, idle, interchange, recon, sohc, start, surges, truck, trucks, year, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
