balancing brake drums - Ford Truck Enthusiasts Forums
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Old 03-08-2006, 03:05 PM
beartracks's Avatar
beartracks beartracks is online now
beartracks is starting off with a positive reputation.
Does anyone balance brake drums anymore?
Old 03-08-2006, 03:11 PM
EricJ EricJ is online now
EricJ is gaining momentum as a positive member of FTE.EricJ is gaining momentum as a positive member of FTE.
interesting question, you could check it on a bubble balancer and use a drill to balance it.
Old 03-08-2006, 03:45 PM
highway90's Avatar
highway90 highway90 is online now
highway90 is starting off with a positive reputation.
I think that due to price drops from local auto parts stores (Autozone, NAPA) over the past 10 years, it is cheaper to simply replace the drum than do an old fashion "drum turn" + balance..
This is probably why most shops will ask you "Why do that?"
my .02 cents...
Old 03-08-2006, 03:54 PM
my .02 cents...
And being CHEAP, what makes you think they're balanced very well?
Old 03-09-2006, 12:49 AM
lscolonel lscolonel is offline
lscolonel is starting off with a positive reputation.
I found if you get the really good quality drums etc like Raybestos PG their usually ok out of the box.
Old 03-09-2006, 01:04 AM
MR_J_DAHMER MR_J_DAHMER is offline
MR_J_DAHMER is starting off with a positive reputation.
Balancing
Quote:
Why? Are u racing at over 250 miles an hour? Hemorids hurting? Just kidding, If you really want the drums balanced correctly, 1st have your tires/rim assembly balanced on a computer spins balancing machine. 2nd, Go to the oldest front end shop in town and see if they still use the old, on vechile, spin balancer. It works with a mark on the sidewall and a flash from the balancer. It balances the rims, tire, drum, axle, everything that spins, get balanced. Since the rim/tire combo was spun earlier, any weights added, are from the imbalance of the rotating assy. Now u r ready to go 250 plus....
WTB BRAKE DRUM bfktwb4 WTB - Parts & other 8 03-14-2016 01:39 PM
F6 brake drum limits? Mixer man 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 09-03-2015 09:59 PM
Drum/drum proportioning valve hillcountryflt WTB - Parts & other 7 02-01-2015 07:33 PM
Inboard Drum Brakes wintersg3 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-28-2014 10:51 AM
Wanted rear brake drum for 1950 F5 animaldawg 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-26-2014 09:40 AM
Tags
balancing, brake, drums
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
