1993 Axle code H9B - Ford Truck Enthusiasts Forums
1993 Axle code H9B
Old 03-08-2006, 01:47 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
1993 Axle code H9B
From the decoder an H9 is a 3.55 Limited slip. What's the B? Does that indicate the front is LS also? Never seen it before.
It's a 1993 F150 4x4 5.8L E4OD.
Old 03-08-2006, 02:25 PM
cbfomoco cbfomoco is offline
cbfomoco is starting off with a positive reputation.
i have a 94 with the same code. dad ordered it for his office and we bought it later. but yet mine is posi front and rear with 355's we will see what anyone else says.
Old 03-08-2006, 02:38 PM
phoneman91's Avatar
phoneman91 phoneman91 is offline
phoneman91 has a good reputation on FTE.phoneman91 has a good reputation on FTE.
My 1992 Ford Shop Manual states that the third character would be a "2" if the front differential was a factory limited slip.
Perhaps that "2" became a "B " in 1993 and 1994 ??
Old 03-08-2006, 02:41 PM
phoneman91's Avatar
Quote:
How does the factory front limited slip differential handle in snow and ice and on dry pavement when the front hubs are engaged??
Old 03-08-2006, 04:26 PM
it is a bear on pavement with the hubs in. you deffently have to be awake. kind of likes to go or wonder on the road. does ok in snow. There is a lot of difference in my 93 and 94 and i contribuite it to the posi. even with hubs out they are completly different. Not necessarly bad but differnet. I will get my owners manual out tonight and see what it says about the code. I am kind of shure that on mine it is posi. whith that code.
Old 03-08-2006, 04:38 PM
phoneman91's Avatar
It seems from your description--if the truck tracks like that when the transfer case is in two wheel drive and the front hubs are engaged--your truck most definitely has front limited slip.By the way--only 3.54 front differential ratios had factory front limited slip from Ford. The original owner of my 92 F150 wanted front limited slip--but they also wanted 4.10/4.09 axle ratios to pull a trailer and Ford wouldnt install 4.09 limited slip in the front axle.
Or you could take a look at the passenger side front axle--look at it from behind the passenger front wheel--there should be a sticker that has been placed on the rear of the passenger side axle housing--upside down. This sticker will tell you the axle ratio and if the differential is open/standard or limited slip.
You could also verify if the front axle is a limited slip by jacking up just one of the front wheels --and with the front hubs engaged--it should take at least 20 foot pounds of torque to turn the wheel--with the transfer case in two wheel drive.
Ford only installed factory front limited slip on trucks with manual hubs and with 3.55 rear/3.54 front axle ratios on the F150s.
Old 03-08-2006, 04:59 PM
i have a question too. on the picture of your door tag. there is the DSO spot is the 21 the code or is that somehting else?
Old 03-08-2006, 05:16 PM
phoneman91's Avatar
DSO stands for District Sales Office and when the code is just two characters--it tells you which district the truck was ordered from. Code 21 means:Atlanta,Georgia. The truck was originally ordered from/sold to a dealer within the Atlanta Ford Sales District.
Old 03-08-2006, 05:30 PM
i think mine is 41 could you tell me that one please? thanks
Old 03-08-2006, 05:53 PM
phoneman91's Avatar
41=Chicago. Are you in the Chicago area?
Old 03-08-2006, 05:57 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
in 96 if you had a 2 where your B is than you had a limited slip front axle, so maybe in 93 the B means limited slip front axle.
oops, i just saw that phoneman had already said this, sorry.
ncranchero's Avatar
Old 03-08-2006, 06:00 PM
ncranchero's Avatar
Kind of makes me wonder if I want a LS front....... I don't do much off roadin'/mud slingin'.
Old 03-08-2006, 06:01 PM
nope im in wv and the truck has always been here. was built in va i think. i will have to look again. thanks
Old 03-08-2006, 06:06 PM
ncranchero's Avatar
See the link I added. It's not where the truck was built, rather which District Sales Office the order was processed through. Most trucks I've looked at around here were built in the Norfolk Assembly Plant. I think that's what I remember seeing on the sticker.....
STOLEN Car trailer ncranchero North Carolina Chapter 6 11-28-2015 09:36 PM
**NOS**D3TZ-13A805-A Horn pad,Steering wheel pad ncranchero Ford Truck Parts for Sale 3 11-26-2014 03:50 PM
New 2014 TC ncranchero Transit Connect 3 08-24-2014 04:42 PM
Engine swap info ncranchero 1987 - 1996 F150 & Larger F-Series Trucks 3 04-24-2014 02:38 PM
Looking for a partial OEM stripe kit ncranchero 1987 - 1996 F150 & Larger F-Series Trucks 10 05-17-2012 01:42 AM
Tags
1994, 4x4, axle, code, codes, dso, e250, e4od, f150, ford, h9b, limited, pic, slip, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
