Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-07-2006, 08:54 PM
tomrooster-1 tomrooster-1 is offline
1966 Ford F-100
tomrooster-1 is starting off with a positive reputation.
Help identifiy distributor
I bought this distributor sight unseen and it don't fit my truck maybe somebody knows what truck it fits. Part # FDE12127a has a H 414 on it to. Somebody thinks its for a early flathead V8Thanks
http://i40.photobucket.com/albums/e226/tomrooster/Picture055.jpg
http://i40.photobucket.com/albums/e226/tomrooster/HPIM1137.jpg
http://i40.photobucket.com/albums/e226/tomrooster/Picture054.jpg
  #2 (permalink)
Old 03-08-2006, 03:42 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
PLATINUM SPONSOR
2011 O.E.M BABY!
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
Can not find a "FDE" but FDS-12127-A fits a 272, 302, 332 in 57-63 pickups
Ed
__________________
  #3 (permalink)
Old 03-10-2006, 09:30 AM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
1986 Ford F-350
85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.
william.a.vose
It looks like it is the top for a governor equipt engine. It is a Holley Loadamatic which is the late 40s to mid-late 50s V8s and up into the 60s on 6 cyl engines.
__________________
Bill Vose (Old School Hot Rodder)
1986 F350 crew cab DRW 460ci EFI, E4OD, PMGR starter, 160 amp 3G alternator, 12X3 rear brakes, Traction lock 3.55
1995 Lincoln Continental (project car), 1994 Taurus LX (daily driver)
http://www.oldschoolhotrodder.com
"growing old is inevitable, growing up is optional"
  #4 (permalink)
Old 03-10-2006, 08:28 PM
1966 Ford F-100
85, What is a Holly Loadamatic? a fork lift?
  #5 (permalink)
Old 03-10-2006, 09:49 PM
1986 Ford F-350
william.a.vose
Holley Loadamatic distributors were a vacuum only advance system that basicly were load sensative system. They used a carburetor with both a spark port at the throttle plate and a venturii port. Many of them had a spark valve on the side of the carburetor. They are easily identified by the very large diameter vacuum diaphram and two springs on the breaker plate with no centrifugal advance mechanism. If you look at the top side you can see the springs are angled differently and different strengths. The light spring controls the venturri advance and the heavy one the port spark or no load advance. The curve specs on these will have a very low vacuum value for the first part of the advance curve on the order of .3 to 1.5" hg. Ford used them on the 49 - 53 flat head V8 and 52 - 56 Y blocks and 49 - 51 Flat head 6 and 52 - 67 OHV 6s. A bad vacuum advance on them would kill both fuel economy and performance.
__________________
Tags
12127, adjustment, advance, breaker, distributor, distributors, distriubutor, fde, fds12127, ford, identify, loadamatic, plate, specs, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
