Used Trans fluid for fuel! - Page 2 - Ford Truck Enthusiasts Forums
Old 06-20-2011, 04:47 AM
sand1's Avatar
sand1 sand1 is offline
sand1 is starting off with a positive reputation.
im running 90/10 gained 2 mpg and no power loss also adding a bottle of cetane booster per tank
Old 09-17-2011, 01:09 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
I've run ATF a few times.
Get yourself one of these, a spin on filter element, and a 1 or 3 micron filter (depending on how paranoid you are) and youre good to go. You can even wire it to run off of 12v so your truck powers the pump.
Head over to any trans shop and they are usually happy to let you have some ATF.
Amazon.com: Fill-Rite Diesel Fuel Transfer Pump with Hoses - 12 Volt, 10 GPM, Model# FR1614: Everything Else
Old 05-02-2014, 06:22 PM
polarbear87 polarbear87 is offline
polarbear87 is starting off with a positive reputation.
I've read that you could fry your fuel shut off solenoid by using watf due to small metal filings that gets into the solenoid and fry it, not shure if this true, but if so.. wouldnt filtrering with either a engine oil filter or fuel filter or a mix of the 2 get rid of the particulates in the WATF ?? And if you would set up a filtering unit what would be the best setup ??
Old 05-03-2014, 11:46 AM
sand1's Avatar
Quote:
Yes I used two filters before pumping it in my tank bought filter head at Grainger works perfect wish I could get . A source of fluid I'd burn it again
Old 05-03-2014, 11:57 AM
Quote:
What kind of filter setup did you use on your system ?? Fuel or engine oil setup ?? And would there bee any difference? ?
Old 05-04-2014, 12:10 PM
sand1's Avatar
I bought the filter head at Grainger and I had a portable diesel pump I spliced it into the hose and went to auto parts store and found a oil filter that fit the head. And done worked well
Old 06-20-2014, 03:56 AM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
Oil filters are 22 microns normally, the farm type fuel filters are 10 microns, some filters 4 microns, some water filters are 1 micron, used ATF must be filtered. PSD's may have trouble with higher viscosity oils, Idi's seam to love it, except in cold weather. transformer oil is sometimes mineral oil, up to 70 cetane, 50/50 0-20 full synthetic moter oil (virgin) runs great 150 degrees more egt's =more heat more power, starts fine suntan lotion is mineral oil too. rape seed oil, sunflower seed oil, vegetable oil, hemp oil. the first diesels ran on vegetable oil. ATF is mineral oil. some hydraulic fluid is fire resistant so check it be for you mix it and ruin a batch.
Old 06-23-2014, 02:54 PM
crazytwo crazytwo is offline
crazytwo has a very good reputation on FTE.crazytwo has a very good reputation on FTE.crazytwo has a very good reputation on FTE.crazytwo has a very good reputation on FTE.
Filter, filter, filter.
Water methanol injection rjrandy96 1999 - 2003 7.3L Power Stroke Diesel 0 10-08-2016 11:51 AM
EGT poll who hits what temps with what mods rjrandy96 1999 - 2003 7.3L Power Stroke Diesel 0 09-13-2016 01:25 PM
Put some Auto Trans fluid in fuel, WOW ? Realslowww Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 30 08-04-2014 07:01 AM
Wvo, bio, wmo....... jt371 Bio-diesel, Propane & Alternative Diesel Engine Fuels 34 12-20-2010 06:20 AM
1991 250 351 engine e40d transmission fluid help smitty403 1987 - 1996 F150 & Larger F-Series Trucks 3 12-08-2010 05:26 AM
Tags
73, deisel, diesel, fluid, fuel, trans, transfluid
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
