My Truck Is Sick - Ford Truck Enthusiasts Forums
My Truck Is Sick
Old 03-07-2006, 05:58 PM
bjvagts bjvagts is offline
bjvagts is starting off with a positive reputation.
Unhappy My Truck Is Sick
My 2000 F-250 has started acting funny. I has started idling rough and louder(pre hpx) and it seems like it has a miss in it when its between 1300 and 1800 rpms(not when excellerating). It all started after I changed the oil(rot5-40syn) and filled up the tank. That day it also got really cold and when I excellerated it was very jumpy. My first thought was fuel gelling (fueled up at a different station) but I use the diesel kleen white during the winter. Then when the temp warmed up the truck ran fine. Then the symptoms came back. Since then I have had the truck scanned, no codes and the injectors where tested and all checked ok. The diesel tech wanted to check the fuel pressure at a differnet time. So instead of paying another $80+ to have it check I bought a new fuel pump on ebay for $140. Needless to say still running the same. I replaced the CPS about 12000 miles ago when I had a miss around the 1500rpm (didn't help). Also I've changed the oil and fuel filter and have went to my ussual watering hole and filled up with no change. It seems to have lost some power. Fuel mileage has dropped a little. It isn't smoking. I'm wondering if it's a sensor or something worse.
1999 F-250 SD V-10 Misses during excelleration boss284 1999 to 2016 Super Duty 1 04-03-2013 11:11 PM
excellerator stall DKluke 6.0L Power Stroke Diesel 4 02-24-2011 07:48 PM
Fuel system trouble Rocksetter 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-27-2007 03:10 PM
2000 F-150 with a #6 misfire firebug8109 1997 - 2003 F150 31 01-10-2007 04:19 PM
no power with excelleration 4x4 ext. 1987 - 1996 F150 & Larger F-Series Trucks 0 09-07-2005 02:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
