ether will work... but its not all that safe, if you use a little propane torch (unlit with the gas valve open) it is a little safer as propane is less volatile than ether, if you run it around a spot you think there might be a leak, you will notice the engine idle drop
__________________
2004 Ford F-150 SXT 4.6L 4x4
1986 Ford Ranger 5.0 H.O.
