Aftermarket headlights
I have a 2000 f150 xlt extended cab 4x4 and I just got projection headlights from ebay. They were installed on saturday and I did a smalll amount of driving that night and they were working great. Today as I was leaving for work I realized that the left side high beams would no longer light up, only the right side. Is it possible that there is a wiring problem, or do you think it may just be a blown bulb?
Sorry I meant the low beam is not working. Do you know what bulbs I can change them with? Here is a picture of them I hope it works. They are the black ones
I have the same set almost on my '99 Expy. It takes an "H-3" bulb. makes sure you stick with the 55 watt version as the 100 watt may be hazardous and burn up your wiring. Now, on yours, do you have 6 led lights at the bottom of each or just 3? From the pic it looks like it has the 3. If so, what is in the other holes? I have the ones with 6 led lights per headlight.
