Easiest ways to change headlight bulb - Ford Truck Enthusiasts Forums
Old 03-06-2006, 06:41 AM
Downriver Thunder's Avatar
Downriver Thunder Downriver Thunder is offline
Downriver Thunder is starting off with a positive reputation.
I need to change the passenger side headlight, is there an easy way to do it? I tried to get through the back side but couldn't get in there good enough to correctly put the new bulb back in. Does the whole assy come out?
Old 03-06-2006, 11:43 AM
SledHauler SledHauler is offline
SledHauler is starting off with a positive reputation.
What year X do you have? What motor? I've had both sides of my 2000 7.3 out and don't recall doing anything special. The drivers side (just out yesterday) was a little tight against the battery box, but still do able. Probably a difference in the year or motor, but if no one else has any ideas today, I'll take another look at mine tonight and re-fresh my memory.
Old 03-06-2006, 12:43 PM
It's a 2000 X Limited with the V10. I know the drivers side, there is a canister right there so I would have to take the assy out, good thing this is the passenger side.
Old 03-06-2006, 12:54 PM
With the V10, yours is probably quite a bit different than mine. I'll take a look at my passenger side tonight anyway.
Old 03-06-2006, 01:07 PM
Matt M, PA's Avatar
Matt M, PA Matt M, PA is offline
Matt M, PA has a very good reputation on FTE.Matt M, PA has a very good reputation on FTE.Matt M, PA has a very good reputation on FTE.Matt M, PA has a very good reputation on FTE.
On my 2005 V10 I had to remove the passenger side headlight...drivers side I was able to reach.
Old 03-06-2006, 01:50 PM
How do you remove it? Just pull up the two clips?
Old 03-06-2006, 03:49 PM
Matt M, PA's Avatar
There are two screws between the bumper and headlight. I can't remember where the other hardware-clips, etc are....but it should be evident once you'er there. (I know my Cobra has two blades that slide up and the headlight comes out.)
I used an extension on my 1/4 drive ratchet to get the screws out above the bumper.
Old 03-07-2006, 05:23 PM
RACERX7775's Avatar
RACERX7775 RACERX7775 is offline
PROFESSIONAL KNOW-IT-ALL
RACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to behold
Smile headlights
when i replaced the lights in my 01 limited V10 4x4, i did not have to remove anything. it was a little on the snug side, but they came out and the HID lights went in without a hitch.
Old 03-10-2006, 09:57 AM
BIGRNU BIGRNU is offline
BIGRNU is starting off with a positive reputation.
I have a '00 V10 Limited as well... I was able to replace both headlights by reaching in directly from above. Tight fit, but nothing serious. If you have HUGE hands and arms, you might have some trouble.
Change headlight bulbs? caadoptees 2017 Super Duty 0 10-17-2016 07:04 PM
Drivers side front turn signal? hoss66 1999 to 2016 Super Duty 3 08-04-2016 09:08 AM
Best bulb replacement for headlights? 2006LJ Excursion - King of SUVs 1 01-16-2014 11:01 AM
2012 F250 Headlight Bulb Replacement skscci 1999 to 2016 Super Duty 9 04-07-2012 05:55 PM
LMC headlight harness traxx808 1987 - 1996 F150 & Larger F-Series Trucks 52 01-26-2012 04:30 PM
Tags
02, 2005, bulb, bulbs, change, changing, escape, excursiom, excursion, ford, head, headlamp, headlight, headlights, replace, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
