power steering bleeding
so i did that and i was wondering how long its suppose to take. i did it for a good half hour and it only got mildly better, and when i shut the engine off the fluid foams out past the cap...but if i let it sit for a little the fluid looks normal...is there anything else i can do...could i drain the pump and then refill it and try jacking it up and doing all that again? and if so to drain the pump should i just take off the lines and let them drain into a bucket...any help would be appreciated cuz its getting nice here in wisconsin and im anxious to drive it again and its pretty hard to do without power steering. thanks
There is an article in the latest JP magazine talking about this exact issue.
I will grab it when I get home and reply back tomorrow with info.
I thought I read about an internal O-ring that may be bad if it back fills after you shut off the motor.
Are you checking the fluid level with the engine running or off?
Need to check with engine running.
Good luck.
Ken
Good luck.
Ken
ive been checking it with the engine off...its rather frustrating this whole issue because ive called around to shops and asked them for help and all of them say it is a self bleeding system which i know but then i tell them how can it bleed itself if i can barely drive it...i would be very interested in reading about the article because this has been an ongoing issue and i just want to drive the thing.
Try out these few tricked out threads.
https://www.ford-trucks.com/forums/s...96&postcount=2
https://www.ford-trucks.com/forums/s...2&postcount=10
https://www.ford-trucks.com/user_gal...=94741&width=0
add-a-filter https://www.ford-trucks.com/forums/s...58&postcount=3
-Buck-
-Buck-
Mudslut,
I have scanned the page and wanted to send it to you.
PM me with an e-mail address and I will send it.
It pretty much said the same thing where you are pulling air in from somewhere.
You could remove the pump and pressurize it to 2 to 4 lbs and submerse it under water to find the leak if it is the pump.
I think that if you just bought the pump from an auto parts store, I would take it back and tell them that it is faulty and get another one.
Good luck.
Ken
Good luck.
Ken
