Help identifiy distributor
Old 03-07-2006, 08:54 PM
tomrooster-1's Avatar
tomrooster-1
tomrooster-1 is offline
I bought this distributor sight unseen and it don't fit my truck maybe somebody knows what truck it fits. Part # FDE12127a has a H 414 on it to. Somebody thinks its for a early flathead V8Thanks
http://i40.photobucket.com/albums/e226/tomrooster/Picture055.jpg
http://i40.photobucket.com/albums/e226/tomrooster/HPIM1137.jpg
http://i40.photobucket.com/albums/e226/tomrooster/Picture054.jpg
Old 03-08-2006, 03:42 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Parts Guy Wyatt is offline
Former Vendor
Can not find a "FDE" but FDS-12127-A fits a 272, 302, 332 in 57-63 pickups
Ed
Old 03-10-2006, 09:30 AM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
It looks like it is the top for a governor equipt engine. It is a Holley Loadamatic which is the late 40s to mid-late 50s V8s and up into the 60s on 6 cyl engines.
Old 03-10-2006, 08:28 PM
tomrooster-1
85, What is a Holly Loadamatic? a fork lift?
Old 03-10-2006, 09:49 PM
85lebaront2
Holley Loadamatic distributors were a vacuum only advance system that basicly were load sensative system. They used a carburetor with both a spark port at the throttle plate and a venturii port. Many of them had a spark valve on the side of the carburetor. They are easily identified by the very large diameter vacuum diaphram and two springs on the breaker plate with no centrifugal advance mechanism. If you look at the top side you can see the springs are angled differently and different strengths. The light spring controls the venturri advance and the heavy one the port spark or no load advance. The curve specs on these will have a very low vacuum value for the first part of the advance curve on the order of .3 to 1.5" hg. Ford used them on the 49 - 53 flat head V8 and 52 - 56 Y blocks and 49 - 51 Flat head 6 and 52 - 67 OHV 6s. A bad vacuum advance on them would kill both fuel economy and performance.
Duellym
1947 and Older Ford Trucks
23
06-19-2016 08:33 AM
The Masked Rider
01-09-2016 04:44 PM
Wood.
New Member Introductions
05-24-2013 05:20 AM
Otahyoni
15
06-14-2010 09:14 PM
CN Spots
Mississippi Chapter
39
09-03-2008 09:58 PM
Quick Reply: Help identifiy distributor
