Corn alcohol in Gas Engines - Ford Truck Enthusiasts Forums
Old 03-04-2006, 06:50 PM
4x4bigblock's Avatar
4x4bigblock 4x4bigblock is offline
4x4bigblock is starting off with a positive reputation.
Question Corn alcohol in Gas Engines
my brother in law is setting up for bio deisel. what about using corn alchol ion gas engines anyone know about that? Thinking of growing Corn for alcohol. some for me some for my truck.
Old 03-05-2006, 12:27 AM
oilpan49 oilpan49 is offline
oilpan49 is new and has a neutral reputation at this point.
Another forum I belong too, a fellow member runs corn ethanol in his Ranger. Suprisingly it's not FFV compatible. He lives in Kansas somewhere and he's told me that his truck runs fine with it. Just my .$02
Old 03-05-2006, 01:50 AM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
What percentage does he run? The non FFV motors will run the standard 10% ethanol without issue. I think the 3.8L FFV motor in the wifes Windstar will run on 70% ethanol.
Thread moved to the other alternate fuels forum.
Old 03-05-2006, 09:48 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I've run E85 through several vehicles, electronic carb and injected, and most responded ok, a few did not. Dodge Caravan, 3.0, did not. Sister's (0's Escort responded ok. Some will tell you that severe engine damage may result from using E85 in a vehicle not set up for it, but I have yet to have any experience with that particular problem. I rarely have fuel system problems, and I constantly run 10% I don't have access to E85 regularly yet, but have run some through on occasion as I could. There are quite a few people trying it out on their non-flex fuel vehicles and doing ok on it. It's a choice you have to make for yourself, because there are many opinions. Study up on it and make your own decision if you want to try it or not. There are plenty of naysayers, so just do your homework and make your own decision yea or nay.
Old 03-05-2006, 11:12 AM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
Quote:
Read the thread "pure alcholol" in this forum.
Old 03-07-2006, 10:02 PM
ok, interesting stuff guys. but can i run it in y old 460? and what percentage. where does it come from. can i make it ? is it cheaper than gas? i have to rebuild my 390 can i build it to burn this? and whats ffv? sorry for all the questions but i am new you have to start out somewhere.
thanks mike
Old 03-07-2006, 11:57 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
If you have to rebuild a motor, it opens up all sorts of cool options. Remember, the octane rating of E85, if I remember correctly, is around 105. Thus, you can build nice high compression engines to use it. The only thing I'd be concerned with is cold starting. Most FFV's use a heated intake manifold to assist starting. The 15% gas also assists starting. I think an intake with an exhaust cross-over passage would help after the engine fires off. If I had to run it, I'd get a block heater and make sure to use it.
FFV = Flex Fuel Vehicle. One made to run either gasoline or E85.
Can you run it in your old 460? Probably. If it's carbureted, simply increase the jet size a few sizes, until the plugs read normal. You might want to go a little hotter on the plugs. Also bump the timing up a bit. Like I said before though, cold starting might be kind of a PITA.
Old 03-08-2006, 12:53 AM
realy informative. this the first i know of this stuff. i want to change the intake manifold anyway on my 460 it was rusty. so i can get a heated one hhm. any idea where i buy these parts and the fuel? whats the price? and whats the power like with it? promise i wont ask to many more questions...
really thank you.
Old 03-08-2006, 11:49 AM
what about the seals on the old engines can i have problems such as shrinkage and drying.? and is there zinc coated tanks and things to get damaged on a 73. whats is the price and where do you buy it?
Old 03-08-2006, 01:29 PM
From what I understand, the seals should be OK, if it's got a recent carburetor rebuild kit with new gaskets in it. A remanufactured fuel pump should work with ethanol. My theory is that if it works with the 10% ethanol you buy at the gas pump it should work with 85%. It will probably stir up some of the accumulated gunk in the gas tank, so a good cleaning is in order before use.
I'm not that familiar with the 460's, so I cant help much there. My interests are mostly in the FE's. So if you wanted to build that 390, stop by the FE forum.
Where to buy the fuel? Check here:
http://www.e85fuel.com/database/search.php
Power will be significantly more than gasoline. This comes from the fact that as it vaporizes, it cools the air and results in a denser air charge going into the cylinder. Also, if you increase the compression ratio of the motor, you get more power there too.
Old 04-05-2006, 12:07 AM
Bdox's Avatar
Bdox Bdox is offline
Iconoclast
Bdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputation
See this Automotive News article:
http://www.autonews.com/apps/pbcs.dl.../60217020/1003
Corn Shack in San Antonio Doug351 Texas Chapter 0 12-27-2013 04:38 AM
fresh corn oil. wycowboy Bio-diesel, Propane & Alternative Diesel Engine Fuels 5 12-30-2009 03:31 PM
gas prices suck i'm gonna run mine on moonshine mstoned1 Offroad & 4x4 57 05-15-2005 02:13 AM
Anybody burning corn??? wyldstallyn73 General NON-Automotive Conversation 32 01-01-2005 04:18 PM
*Scampers to the next topic on his agenda* "Enviro-Diesel" Greywolf General NON-Automotive Conversation 3 04-22-2002 07:08 AM
Tags
alcohol, corn, f150, ford, gas, good, ranger, running, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
