Rubber hose between filler pipe and gas tank on 1990 Ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-03-2006, 10:11 PM
kabcpapc kabcpapc is offline
kabcpapc is starting off with a positive reputation.
I just inherited a 1990 Ford Ranger standard cab short bed 2.3L 5 speed manual. The gas gauge didn't work so I got a mechanic to replace the sending unit. It now works. But when I try to fill the gas tank there is gas that runs out of the rubber hose between the filler pipe and the gas tank because the rubber hose is so old and has cracked. The dealership won't sell just the rubber hose. They will only sell the complete filler pipe assembly to the tune of $110 at cost!!! There has to be a cheaper way to replace just the hose but what kind of hose could be used for gasoline? Any ideas from you guys?
Old 03-03-2006, 11:29 PM
Rangerman Stan Rangerman Stan is offline
Rangerman Stan is starting off with a positive reputation.
Try a NAPA auto parts store or Car Quest auto parts. This was suggested by one of the guys behind the counter at a discount auto parts store in my area here in Mi. He also suggested that radiator hose will work if you have a somewhat straight shot to the tank so the hose won't kink and some stores have some that is large enough in diameter to fit the tank and the filler neck. The only other option would be to find one in a wrecking yard.
Old 03-03-2006, 11:33 PM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
Yeah either boneyard it (cheaper) or just check Autozone, Napa, Western Auto, etc. If you take yours off and take it with you you'd have a lot easier time finding one, though it's not the easiest to remove.
Old 03-04-2006, 03:36 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to all
Whenever I need quality, specialty hose products, the name Parker comes to mind. Visit their website and see if their catalog is online or contact a hose supplier.
Old 03-24-2006, 02:20 AM
hood's Avatar
hood hood is offline
hood is starting off with a positive reputation.
My 91 ranger has a cracked filler hose too. About 6 years ago i used some 3M sealant (looks like tar) to fix my cracked hose. I had to smear the sealant onto the hose with my fingers. It's a tight reach but i got enough on to seal the cracks. It needed 2 layers to fix it. Let it cure for a few hours before topping off the tank.
Go to your local boat marina to look for your rubber hose. They usually have an assortment of hoses for outboard motors.
Good luck.
Rear Tank Filler Tube. William 1987 - 1996 F150 & Larger F-Series Trucks 1 02-01-2016 09:17 PM
How To: Install New Fuel Filler Neck In Gas Ford Excursion ExploringNH Excursion - King of SUVs 1 01-21-2014 04:46 PM
70 Crew Cab aux. fuel tank abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 15 10-02-2013 01:19 PM
fuel filler hose tabijan 1968-2013 Full Size Vans 6 12-14-2012 03:50 PM
Replaced side gas tank, now I need a filler hose andydunks 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 06-24-2012 03:45 PM
Tags
1990, 35, auto, filler, ford, gas, gasoline, hose, install, king, parts, ranger, remove, rubber, rubberhose, tank, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
