5.4 Check Engine Light, Egr Valve Code - Ford Truck Enthusiasts Forums
Old 03-03-2006, 08:24 PM
shmitee shmitee is offline
shmitee is starting off with a positive reputation.
1999 Triton 5.4 Around 115000 Miles. It Is Running Sluggish And Has Been Shifting Funny. When I Stomp On It It Will Shift Up And Only Hit The Passing Gear If It Is Floored. I Took It To Autozone To Read The Code Because The Check Engine Light Has Been On And It Was Reading The Egr Valve. Replaced It And Nothing Changed Reset Light And Came Back On And Read The Same Thing? Any Suggestions?
Old 03-03-2006, 09:50 PM
Moore FOMOCO Moore FOMOCO is offline
Moore FOMOCO is starting off with a positive reputation.
Was it a Code P0401? For EGR insufficient flow? It could be one of ??? things, Remove the EGR valve and clean the ports (wire brush ONLY, NO Chemicals.) Not saying this will fix it, just Trouble-shooting System. Cheapest and Easest way First, right? Also, check DPFE (hoses, for loose connection) sensor, EGR Vac. Regulator.
Old 03-04-2006, 09:16 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Another blown AutoZone diagnosis and another wasted EGR valve.
Check the 97-03 F150 forum for hundreds of posts concerning the common EGR codes.
Usually, its either clogged EGR ports or a faulty DPFE sensor, but do the vacuum test to isolate.
Steve
Old 03-04-2006, 12:22 PM
kspilkinton's Avatar
kspilkinton kspilkinton is offline
kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.
Quote:
Much like O2 sensor replacement when the codes says O2 sensor... in reality, for instance, it is the MAF. All these sensors tie together, so unless it's a complete failure, a code shouldn't necessarily lead you to replace the sensor. Do some other checks of the system first. Post up on the site if you have a question, don't trust an auto parts sales person just because they can hold a code reader.
-Kerry
Old 03-04-2006, 08:32 PM
pronstar pronstar is offline
pronstar is starting off with a positive reputation.
DPFE sensor is cheap and easy. Rockauto.com has them for around $40 I think. You can easily check it's operation with a voltmeter. The EGR valve is about the same price there.
If you have EGR issues, may I also suggest that you make sure the EGR tube is clear. It's the tube that goes up from the exhaust manifold to the EGR valve on the driver's side.
P1451 Code, yes I have been searching!! 86capriASC 1997 - 2003 F150 13 08-07-2010 11:48 PM
97 F-150 5.4 runs rough in mid range maxxf150 1997 - 2003 F150 6 01-01-2010 12:05 PM
Rough Idle in Park and Check Engine Light On jwillyf150 2004 - 2008 F150 1 05-13-2008 11:17 AM
92 full size van, 5.0 l, trouble code 328 harvaz 1968-2013 Full Size Vans 4 11-17-2005 10:19 AM
99 Mercury mountaineer code 141 / 1402 jad Explorer, Sport Trac, Mountaineer & Aviator 3 05-15-2005 09:30 PM
Tags
03, 2000, 54, 54l, check, clogged, egr, engine, engines, f250, ford, light, shootings, triton, trouble, tube, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
