2006 V10 Delays
#241
Originally Posted by AlwaysBulkin
well, I found my first issue. The 12.5K trailer hitch seems to have the holes cut a bit low. My existing 2" slide in receiver won't allow the pin to fit through when inserted in the truck's hitch. It apears that the holes are cut nearly 1/8" too low. I've used this insert in my last 3 trucks and never had an issue.
#242
Originally Posted by Fredvon4
For the windows, I use and endorse WeatherTech in channel window vent shades...
Sorry Monsta...shameless non V10 post
AB: I'll check into those Deflecta things. Do you believe they actually do something or is it just an accessory you have gotten used to putting on your vehicles? Not really sure if they actually work or not, but was considering giving them a try.
Michael
#243
#244
Michael
Michael
#246
#247
Originally Posted by captchas
i beleive your correct art. i have used my hitch in my last 4 trucks factory receivers no problem/try rocking it up and down by the ball . and yes the bug guards screw into the spots the rubber seal would normally go into.
#248
Originally Posted by rob17
The only issue I've had with bud deflectors is that they tend to affect the windshield washer spray when driving at highway speeds. It seems that the spray will go every except on the windshield. Of course I guess that is how they keep the bugs off the windshield.
Thanks,
Michael
P.S. Not that I have ever mentioned it on these forums, but MY TRUCK GETS BUILT THIS WEEK!!!!
#249
#250
what dose this have to do with what i said about mounting? and try reaiming the jets . bugs the guard is for bling dosn't help with bugs here at all. esp. mayflies and love bugs. the jets rob take a good look i think they can be reaimed a little. not possitive but most can be . and jepppers another guy ready to retire. near it any way
#251
Oops, you're right, I totally forgot about the bling factor.
Blings would be HUGE wheels (with spinners?), shiny steel (stainless or gold?) all over the truck. Wheel well covers, gas cap covers, lots of chrome replacements for the grill, etc. Want to get a bling explanation? Watch BET for 30 seconds, if you can stomach it.
A piece of dark plastic to help blow off (theoretically) some bugs does not fall into the bling factor.
Michael
#252
#253
#254
gepers ernie . here they mix it all up and spead it out. after a storm you can't tell what color you had to start with. they wind up all white and you wash off 100 pounds of sand and gravel.
the so called bug guards "around me we call them bling as don't do that much but look good". esp. right now with huge swarms of black trout loving may flys. my nose looks like smake heaven every thing is black or covered with bug guts.
