292 engine swap
The number of questions that appear on FTE, and other sites (clubhotrod, hotrod.com, Ol'School, etc.) regarding motor swaps are very high. Most of the guys asking the questions on swaps dont have a lot of experience, and therefore the change is a large consumer of time and money. From personal experience being in the group of nonexperienced and having gone through a swap, I would suggest you rebuild the Y. It is as nostalgic as the truck you find so appealing, and will give equal or better service than the replacement you are considering.
However, if you are dead set on swapping the motor, then also just throw away that humongous 4 speed and put in an updated tranny to go with your new motor. You will have to read a lot, and ask a bunch of questions along the way.
The 59 292 is one of the best of the y-blocks, and it very likely has some of the best best big valve heads bolted to it. It can be bored .110" and a 312 crank can have its main journals turned to fit the 292 and you'd have a pretty decent 322" engine. Check out http://www.ford-y-block.com/.
8lugthug
05-05-2014 06:20 PM
69supercj
10-18-2013 06:59 PM
fordf101968
17
05-11-2013 09:17 PM
jl_hovey
01-24-2010 08:59 AM
