Go Back   Ford Truck Enthusiasts Forums > General > Ford vs The Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
  #1 (permalink)
Old 03-03-2006, 12:31 AM
mschultz mschultz is offline
Garage is empty, add now
mschultz is starting off with a positive reputation.
New 6.7 Cummins & New Dodge Frame Formally Introduced
http://www.turbodieselregister.com/06ntea/
Looks like Daimler has dropped the boxed-section frame on their heavy commercial truck and adopted a C-section frame like the Super Duty.
Also, note the conservative numbers listed for the new motor and take a look at the new 6-speed automatic transmission.
Guess Ford had the better frame design all along.
-Mike
  #2 (permalink)
Old 03-03-2006, 12:38 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
well it seems they are headed in the right direction. they must have figured out that they can't build a auto tranny to save their lives so they contracted with AISIN . AISIN makes good reliable units. but after all its still a DODGE!
  #3 (permalink)
Old 03-03-2006, 02:40 AM
Galizien's Avatar
Galizien Galizien is offline
Galizien is starting off with a positive reputation.
The boxed frame is nothing more than the company trying to gain a marketing advantage over the other. The boxed frame does however add alot of extra weight, and a C frame has proven to be more than enough on light to medium duty trucks. It provides proper flex and enough strength for most any job these trucks will see. Its also lighter, and much cheaper to make.
Look at how straight and low profile that frame is, closer to a tractor trailer frame. No uneeded bends or twists.
Damn the new dodges look hot as hell.
  #4 (permalink)
Old 03-03-2006, 04:21 AM
Logical Heritic Logical Heritic is offline
Logical Heritic is new and has a neutral reputation at this point.
What is proper flex?
  #5 (permalink)
Old 03-03-2006, 05:22 AM
MEPR MEPR is offline
MEPR is starting off with a positive reputation.
Well i am vary happy to see that Chrysler is going whith AISIN trannies. These guys should handle Cummins power no problem...
__________________
my truck is twice as old as me!
  #6 (permalink)
Old 03-03-2006, 09:29 AM
Batgeek's Avatar
Batgeek Batgeek is offline
Batgeek is starting off with a positive reputation.
Took them long enough, but it looks like they are going in the right direction. As others have said it's about time Dodge faced the fact that they can't build a transmission worth a damn. I'd be interested to see how the engine performs with all the new systems they have put on it. The magazine article makes it sound great. It is a completly new engine design so I would expect some bugs to appear. When will they start making the outside of the truck look better?
  #7 (permalink)
Old 03-03-2006, 11:07 AM
RY54 RY54 is offline
RY54 is starting off with a positive reputation.
"We asked if this transmission (new 6spd auto) was going to be used in the regular 2500 and 3500 trucks and were told that the '07 model will continue with the 48RE."
This doesn't make any sense, unless its a cost/fitment issue....
__________________
2000 F250 4x4 VX Crew lariet
6" lift 35/12.5 bfg A/T auto 3.73
K&N FIPK, JBA exhaust
Full memphis audio system with 15" sub behind seat
228,000mi, SOLD
  #8 (permalink)
Old 03-03-2006, 11:19 AM
Galizien's Avatar
Quote:
Automobile frames should have a certain amount of flex to them, the boxed frames they put on trucks lately have been almost too stiff.
  #9 (permalink)
Old 03-03-2006, 11:35 AM
73Fastbackv10's Avatar
73Fastbackv10 73Fastbackv10 is offline
73Fastbackv10 is starting off with a positive reputation.
That's the same reason why big rigs have C-channel frames. If the frames were boxed, the torque from the engine would rip them apart. I saw that on Trucks!
__________________
1980 Ford Bronco, 351M, edelbrock intake and carb, Lincoln Mark VIII electric fan, Flowmaster, Holley Black electric fuel pump.
  #10 (permalink)
Old 03-03-2006, 12:32 PM
Batgeek's Avatar
Agreed the story got wierd at the end stating that the new engine, transmission, and frame would not be used in the regular 2500/3500. Tell me if I'm wrong, but I thought that the 5.9 would not meet the 2007 emmission standards. I see alot of Dodge lovers buying chassis cabs and ordering beds to put on them. I know I would if Ford came out and said "we are only putting the new 6.4tt and 6 speed auto in the chassis cabs". Of course they may be doing it this way on purpose. They won't sell as many chassis cabs as they would regular trucks, but the chassis cabs will see more use in a shoter period of time. This would give them a "test market" to work any bugs out before it went into large scale production. I'm probably being paranoid.
  #11 (permalink)
Old 03-03-2006, 01:51 PM
Galizien:
The boxed frame- as used by D-C in the 2500 and 3500 actually weighs LESS than the C section Ford due a lighter gauge steel. You are correct about flex though- All other things being equal, box section frames tend to be stiffer up to the point where they fail- and C section frames handle deflection better.
The trade-off is that a frame that flexes will make a poorer handeling truck- soft. But stiff frames tend to fail when abused.
I guess one probably makes sense for lighter trucks where overloading is not going to be a significant issue and the other frame makes sense once you are in the range of trucks where frames simply have to flex in order not to fail.
-Mike
  #12 (permalink)
Old 03-03-2006, 03:30 PM
A. Michael Foxtrot's Avatar
A. Michael Foxtrot A. Michael Foxtrot is offline
A. Michael Foxtrot is starting off with a positive reputation.
Quote:
They can do this if the MY 2007 trucks are built in calender year 2006. The current engine will still be viable until Dec. 31, 2006. All the things I've read on the new emission standards seem to reference a calender year, not a model year. So perhaps they'll come out with a MY 2007.5 once Jan 1 approaches with the new engine onboard.
__________________
(Cheap, Fast, Reliable...Pick any two)
1998 F-150 S/C XLT 4X4 4.6
2005 F-350 C/C Lariat 4X4 6.0
Click me to see what I drive
  #13 (permalink)
Old 03-03-2006, 04:42 PM
BigF350 BigF350 is offline
2000 Ford F-350
My Garage
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
adrian.erks.harris adrianerksharris
I think the optional exhaust brake is a cool idea though...
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
  #14 (permalink)
Old 03-03-2006, 07:07 PM
ford4.9's Avatar
ford4.9 ford4.9 is offline
ford4.9 is starting off with a positive reputation.
" While this system is much more complicated than the existing high-pressure, common-rail engine. However, it has been used by Cummins since 2002 with 300,000 engines currently on the road and over 30 billion miles on the road. "
Ford/ Navistar did that!! It's called the 6.0
__________________
1988 F150 4.9 M5od
  #15 (permalink)
Old 03-03-2006, 07:22 PM
Yeah, good point. Isn't that about 6,000 of those engines per state according to Cummins? With that many eninges, it sure seems like we would all know somebody with that new engine... Perhaps they mean "300,000 engines" but not necessairly 300,000 new 6.7 Tier II engines already on the road. Or maybe they 300,000 engines with the new Tier II compliant system, but not 300,000 6.7 engines.
The statistic seems a bit odd.
-Mike
Tags
67, cframe, cummins, dodge, ford, frame, frames, intoduce, new67cummins, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
