Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-02-2006, 03:09 PM
yardleytc is starting off with a positive reputation.
Unhappy help
I doubt that i am in the right section but i need help. i have a 98 windstar and the interior lights will not go out it keeps saying that a door is ajar. I was told to wd40 the snesors and joints and that worked for a little bit but now i am down to having to take the fuse out which means i have no power windos either. I though maybe it was the wedge front cause i have noticed that part ofit is broken, but when i ordered the part i thought i needed i got the opposite part of what i need. I cannot find anywhere to see what even the part i need is called. i am so confused and sick of my van. i just replaced the powersteering pump and pulley and now i have to replace the timing cover gasket and then i need to reploace my manifold runner controls. I don't know if ti will ever end. But please if someone can help me with my first 2 issues i would be so appreciative
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-05-2006, 08:01 AM
Rockledge's Avatar
Rockledge has a very good reputation on FTE.Rockledge has a very good reputation on FTE.Rockledge has a very good reputation on FTE.Rockledge has a very good reputation on FTE.
Does the Windstar have the 3.8L in it? Try this forum:
http://www.ford-trucks.com/forums/forum50/
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #3 (permalink)
Old 03-05-2006, 12:16 PM
Kruse is starting off with a positive reputation.
Quote:
The problem with these "door ajar" sensors is that they sit under the door latch facing up and collect water, dirt and car wash overspray. Ford should have put them on top of the latches and had them facing down. Oh well.
Anyway, spray them LIBERALLY with WD-40 and open and close the door a hundred times. The dealer will have a hookup that will tell you which door is the problem, but usually it's the driver's door. (Because it's the door that gets used the most) However, if you've got a significant other that goes with you all the time, it may be the passenger door also.
If this does not fix your problem.......you need to replace the sensor. Not a fantastically easy job, but it can be done by a shade tree mechanic.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
