loss of power in '92 Ranger
My 92 Ranger with 4L V6 was running well until I started it a couple mornings ago and suddenly not all was well. There is a noise like a blowing wind that gets louder as I accelerate and stops if I let off the gas. In addition to this I lose speed on he highway when climbing a hill no matter how much gas I give it. I have been losing coolant lately that I was going to tackle in the spring (I'm on the north shore of Lake Huron so it's a bit cold right now) but I don't think this is the problem. I have been running it too often with the gas below a quarter tank so I will be changing the fuel filter hoping that resolves the problem. I am an hour away from the parts store (mostly uphill) so if there are any other things I should check before I head to the store tomorrow I could really use any suggestions.
Do you get this sound when you are sitting still, and just rev the engine? If you do, then I agree it could be a locked up fan clutch. But, this problem will not make you loose coolant, which might be a more serious problem. Your vintage of 4.0L had a problem with the lower intake bolts coming loose. When this happens, you will loose coolant, and oil.
Originally Posted by RangerPilot
Try and figure out where that coolant leak is coming from. Wash the block up and the keep an eye on it after driving.
Sounds like you have more than one probem here.
I agree with Bob, the coolant loss is a more serious problem & should be run down right away.
You didn't say if you have signs of a external coolant leak, but If it isn't & the engine is ingesting coolant, that sure isn't good for it, nor the O2 sensors & cat converter. The O2 sensors can be taken out by a surprisingly small ammount of coolant, they just aren't tolerant of it at all!!!!
Check the leak & fan out & let us know what you find.
Hi and thanks to all those who are helping. I do believe I have two problems.
The fan does not turn when the truck is off so this is a problem. When getting under the truck, it looks to be the lower rad hose leaking. I will replace that today. I am losing oil but I think that is from the oil pan gasket which I will replace in the spring (I'm loosing about a litre(yea, I know; Canadiana talk) every thusand miles or so.
There are not many wreckers in this neck of the woods. What other fords or Ranger years fit this engine? Will I harm it driving it to go gor parts?- All highway driving.
Well it's good to hear the coolant leak isn't serious & the fan problem is addressable.
On your oil leak, you might try torquing up the oil pan fastners, in case some have loosened up in the cold weather, maybe if your lucky it'll stop it or at least slow the leak down some, until the weather warms up enough to work outside.
I'll second the last post. If your little Ranger suddenly sounds like a big honkin semi, chances are your clutch fan is engaged all the time. With the truck off, see if the fan will spin freely. If not, time to hit up a junk yard!
__________________
__________________
It doesn't matter if it's an auto or manual, the fan can stick either way.
At least the coolant leak isn't serious as was said.
How much oil can we hold in litres? A litre per thousand miles surely does sound like a lot to me. With a 4.0L, I'm willing to bet any 4.0L oil pan from a Ranger or Exploder of similar year will fit.
prmac, also check your PCV valve & make sure it isn't clogged or iced up, as that could cause excessive internal crankcase pressure & force oil out of seal & gasket weak spots.
michaelbarry, as has been said, on the fan thing, it doesn't make any difference if it's a straight or automatic, the fans are all the same.
Having it locked up all the time is noisey, wastes engine power, puts more stress on the water pump bearings, fan blades, belt, your nerves & soon your wallet!!!! LOL
Sounds like you too would be a good canidate for a salvage yard visit!!!! Good hunting!!!!
