Timing specs & idle speed for a 1978 F250 300 6 Cyl
I have a 1978 F250 with a 300 Cu In 6 Cylinder the timing & idle speed spec sticker is missing & the manual says to refer to it. I suspect that the timing is somewhere between 6 degrees & 8 degrees BTDC & the idle is somewhere around 450 - 650 RPM.
Has anyone access to a manual that has this information or maybe a truck of this year with this motor that has the spec sticker still on the valve cover.
Any help you can give will be appreciated.
Regards, Bartll
Regards, Bartll
