Ranger-Tire size??? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Ranger-Tire size???
Old 03-01-2006, 11:17 AM
stang3O2 stang3O2 is offline
stang3O2 is starting off with a positive reputation.
Ranger-Tire size???
Ive got a 1990 Ranger, two-wheel drive...that came with the "americna racing rims, (i believe thats what they are) option! Goodyear wingfoot tires I believe is what was stock. The tires have been replaced in the past with a different size than what came on the rim, anyone know what size tire that is that came with that option?
Old 03-01-2006, 11:45 AM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
Does the label in the door jamb still have enough ink on it for you to read what's on there?
If not, I think tire rack's website will list all your factory optioned tires for a given year.
Old 03-01-2006, 12:30 PM
Thanks for the info Alfred...Yah the door sticker has pretty much lived its life and is dying away, haha! I will try that web site, thanks again!
Old 03-01-2006, 02:10 PM
Troyandchristie Troyandchristie is offline
Troyandchristie is starting off with a positive reputation.
I am not positive if 90' ranger and a 92' explorer would have the same size tires or not. I dont think they changed tire sizes between the 2 years, but the 92' explorer had 235/75/R15 if that might be of any help
Old 03-01-2006, 02:16 PM
If you do look on a web site to find the correct size I would measure the diameter of the rim to make sure it is correct, because I have a 98' ranger and all the web sites I checked said it only came with 15" rims but on the door it calls for 16" rims
Old 03-01-2006, 04:17 PM
Madmike33's Avatar
Madmike33 Madmike33 is offline
Madmike33 is starting off with a positive reputation.
My 92 4.0 4x4 originally came with 215/70r15 So I doubt the 90 2wd came with 235/75r15. Call the dealer and ask them what your truck rolled out on. All they need is the VIN for your truck.
Hope this helps
Madmike33
Old 03-01-2006, 08:26 PM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
My 91 XLT came from the factory with 215-70-14 tires. Low line models came with 195-70-14 tires. Note wheels are 14".
Old 03-01-2006, 09:45 PM
Michigan66...did your truck have the "american racing" looking wheel on it. Prob aluminum rim with about 8 holes that circle the rim? I thought it was an option that came a different rim. I know the tire was "short and wide" so to say on the rim. From doin some research on thinking it might have been a 225-70-14. Thanks for all your guys input!
Old 03-01-2006, 09:50 PM
Rangerman Stan Rangerman Stan is offline
Rangerman Stan is starting off with a positive reputation.
My 90 Ranger XLT supercab 2.9 5spd has the American racing wheel option and they are listed on the door sticker as P215/70R14. The same wheel was available for the Explorer but in a 15 inch and the tires were usually 235 series.
Old 03-01-2006, 10:04 PM
I omitted that my Ranger is 2wd also. Sometimes when buying tires the 14 inch size is a stumbling block because the tires I have wanted to buy were only available in 15 inch or larger.
Old 03-01-2006, 10:08 PM
Yah mine is the 2wd ext cab 5spd 2.9 also! I just wondered if what was on the door sticker is for the original tire setup...or if it is actually for the "amer racing" size wheel option? I was thinkin that it was prob a 225-235 series like you stated about your explorer! Thanks again!
Old 03-01-2006, 10:18 PM
I've seen other XLT Rangers with steel wheels which have the 215/70R14 tires as well making me think the sticker covers both types of wheel options.
1992 F350 4WD Rim Size regidog Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 12-14-2016 03:10 PM
I need an 18" rim for a spare The Tiger Brakes, Steering, Suspension, Tires, & Wheels 8 03-02-2016 03:19 PM
Help Choosing Wheels for 68 F-250 fettsvenska 1967 - 1972 F-100 & Larger F-Series Trucks 17 01-08-2016 06:42 PM
2011 Edge Sport Tire size increase GerritMaxwell Crossovers 5 02-02-2015 01:55 PM
Factory wheel specs '77highboy 1973 - 1979 F-100 & Larger F-Series Trucks 21 05-15-2014 05:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
