Auto to Manual Hubs - COMPLETE - Page 5 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #61
Old 11-25-2009, 10:04 AM
GUNNERDOG's Avatar
GUNNERDOG GUNNERDOG is offline
GUNNERDOG has a very good reputation on FTE.GUNNERDOG has a very good reputation on FTE.GUNNERDOG has a very good reputation on FTE.GUNNERDOG has a very good reputation on FTE.
links don't seem to be working anymore any way to get them back? I would like to do this...
  #62
Old 11-25-2009, 10:25 AM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
Same procedure, different link:
Auto to Manual Lockout Hub Conversion pictures from cars photos on webshots
Very simple to do.
  #63
Old 11-25-2009, 11:41 AM
GUNNERDOG's Avatar
Thanks! That answers my question of what to do with the vac lines, however, i still have a question about this screw... do i remove it? It looks like it is just there for shipping purposes... The instructions provided with the hubs do not mention it.
(i stole this picture from this link: Auto to Manual Lockout Hub Conversion pictures from cars photos on webshots )
THANKS!
  #64
Old 11-25-2009, 01:58 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
No, leave that screw right where it is. It's so when you take it apart, the locking ring (and spring?) don't fall out
  #65
Old 11-25-2009, 02:00 PM
Krewat's Avatar
That document missing is my fault. I recently revamped one of my websites, and the document didn't make it over.
It's BACK!
  #66
Old 11-25-2009, 04:21 PM
GUNNERDOG's Avatar
Sweet thanks!
reps given
  #67
Old 11-26-2009, 02:20 AM
palmer8996 palmer8996 is offline
palmer8996 is starting off with a positive reputation.
Link still not working
Krewat,
I still can't get the link to work. Any chance you can pm me a better link?
Thanks,
Palmer8996
  #68
Old 12-03-2009, 02:10 PM
FlounderHound FlounderHound is offline
FlounderHound is starting off with a positive reputation.
Great info!
Hey guys, I just joined up so that I could share my recent auto hub experiences with you and also try to get a little more opinions. I use my F250 SD for fishing on the Outer Banks of NC, and spend (usually) a week at a time in soft sand. This October, I got stuck because my 4x4 light indicated I was in 4WD but I wasn't. That began my education on these things. I took it to the shop in Charlotte to have it fixed, and frankly, I think since it started working again, they did nothing. The mechanic just told me that he didn't like the system, and that he would switch to manuals. Well, I went again last week and guess what? Got on the island and had no 4WD. I finally got it to work and was determined to go online and learn more about the issue. Well, that brought me to you and I am learning a lot, so thanks! One place, though, I read that if the autos aren't engaging and the vacuum lines are intact, I should replace the o-rings and lightly grease them, because the problem is likely a leak around those o-rings. Still, I think I'm going manual, so here is what I'd like an opinion on - there seem to be three kinds to consider - Warn, Superwinch, and Mile Marker. Is there a better choice among the three (disregarding looks) for my use in the salt and sand environment?
  #69
Old 12-03-2009, 02:46 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
I have always favored Warn Premiums. Lifetime warranty and they do stand behind them.
  #70
Old 12-08-2009, 09:05 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Quote:
Originally Posted by Krewat View Post
sorry, here's the link:
Super Duty Automatic to Manual Hub Conversion.doc
I editted the original post with the link in it also...
Link no longer works.
  #71
Old 12-08-2009, 09:13 PM
Brian460 Brian460 is offline
Brian460 is starting off with a positive reputation.
Really if they aren't worn out or anything the stock ones act just like manual ones no need to replace them.
I prefer WARNS.
I replaced mine today at work in the snow took about 5 minutes per side. Did it with the tires on, with a pair of pliers and a 9/64" allen wrench.
  #72
Old 12-15-2009, 07:47 PM
Mante's Avatar
Mante Mante is offline
Mante is starting off with a positive reputation.
any luck on the original link? I did get the other link with the photos though..
  #73
Old 12-30-2009, 05:09 PM
Dave 250 Dave 250 is offline
Dave 250 is starting off with a positive reputation.
2003 f250 4x4 gas replacing hubs
Warn tells me i need to use spindle conversion kit 32721 before installing warn standard manual hubs???
  #74
Old 12-30-2009, 05:15 PM
2003 f250 4x4 5.4....I purchased the warn standard manual locking hubs. It tells me that if I'm replacing the oem auto hubs with manual hubs I need to purchase 32721 spindle nut conversion kit before installing hubs???
  #75
Old 12-31-2009, 09:30 AM
I haven't installed mine yet, but as far as I can tell, the instruction sheet is wrong...it is only the pre-2002 vehicles that need the kit I believe.
2017's on Ebay Rasty1 2017 Super Duty 5 10-04-2016 08:41 PM
Features, Descriptions, Unique Service Procedures, and General Diagnostics bismic 6.0L Power Stroke Diesel 0 11-03-2007 10:11 PM
What Wheels Should I Go With? TKAT79 1997 - 2003 F150 21 06-12-2006 05:19 AM
need some help with a part dixiemudder04 Cooling, Heating, Ventilation & A/C 5 03-03-2006 06:09 PM
New Line Converter available! radelow Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 08-04-2005 01:49 AM
Tags
2002, 4x4, auto, automanual, bronco, conversion, duty, f250, ford, hub, hubs, installing, instruction, manual, sd, super, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
