Auto to Manual Hubs - COMPLETE - Page 4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #46
Old 10-12-2007, 07:39 PM
The Grand Pooh-Bah The Grand Pooh-Bah is offline
The Grand Pooh-Bah is starting off with a positive reputation.
Thanks...that works
  #47
Old 10-26-2007, 12:48 AM
ZBIGBIG19TH ZBIGBIG19TH is offline
ZBIGBIG19TH is gaining momentum as a positive member of FTE.
Thumbs up Excursion?
I guess they should work on Excursion also???????
was about to try to repaire mine but just 2 days ago someone stold them
from my wheels.haha poor *******.
thanks
p.s. great stuff great forum
  #48
Old 12-26-2007, 01:02 PM
DeanL DeanL is offline
DeanL is starting off with a positive reputation.
Howdy and Happy Holidays
Great write-up on the conversion.
I have a quick question, did you need the conversion kit as well. I talked to Summit and they say I need an auto to manual conversion kit for $60 extra, but I did not see that in your write-up.
I have a 2001 and the right side just crapped out and I need to get fixed asap as I am going back into snow country this Friday.
Thank and Happy Holidays,
Dean
  #49
Old 12-26-2007, 04:48 PM
Arrowman400 Arrowman400 is offline
Arrowman400 is starting off with a positive reputation.
As far as I know you do not need it. I did not need it for my Warn Hubs
  #50
Old 12-27-2007, 01:33 AM
Smile
Quote:
Thanks for the response. I got a set of MileMarkers at Autozone and installed them this afternoon. I could not see any reason why they should need the kit and they seemed to work great without it.
I am glad to be rid of the OEM junk.
  #51
Old 12-27-2007, 10:17 PM
Packrat Super duty Packrat Super duty is offline
Packrat Super duty is starting off with a positive reputation.
Did you plug off your vaccum line? After installing the manual hubs, and if you had a leak in the auto hub axle seal, you will need to plug the vaccum lines going to the axle. If you do not plug the vaccum line, your air conditioning will default to the defrost vent, when 4 X 4 is engaged.
I read back on the forum after sending this, and I see that the vaccum hub line pulgging was mentioned before....
  #52
Old 12-28-2007, 10:57 AM
Storm Storm is offline
Storm is gaining momentum as a positive member of FTE.
What kind of Grease did you lube with? What did you use to clean up? Brake Cleaner?
I'm thinkin of doing the MM 449SS on my manual hubs.. Hate the factory ones... I don't have ESOF tho, got Floor Shifter
  #53
Old 12-28-2007, 11:47 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Storm if you remove your stock hubs, can you disassemble one and take pictures? I'd love to see if they are as wimpy as the ESOF ones...
  #54
Old 12-28-2007, 01:09 PM
Quote:
Sure can!
I pick up my MileMarkers tomorrow.. $140 bux from Autozone..
Thanks to the OP who posted this.. I was almost going to buy the Warn Premium but couldn't stand that "Yellow" ****.. I wanted something strong to withstand the elements (SS).. Milemarker did that!
OH BTW.. OP, you know your caps are upside down? LOL.. Your "Free" is upside down... Shouldn't it go the other way? LOL
  #55
Old 03-18-2008, 09:50 AM
griffith1967's Avatar
griffith1967 griffith1967 is offline
griffith1967 is starting off with a positive reputation.
does anyone have a part number for mile marker to a 02 ford excursion so I can change to manual hubs...thanks.
  #56
Old 03-18-2008, 11:54 AM
rlh68050's Avatar
rlh68050 rlh68050 is offline
rlh68050 is gaining momentum as a positive member of FTE.rlh68050 is gaining momentum as a positive member of FTE.
Quote:
449SS it the part number.
  #57
Old 03-18-2008, 12:17 PM
Smile PART# FOR FORD eXCURSION
Thanks For The Part # For The Hubs I Already Bought Them FROM Autozone
And Installed Them...TOO EASY...LOL.
  #58
Old 03-18-2008, 01:12 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
OK...I skipped from page 1 to page 4 so don't slap me too hard if this was already mentioned....I read through the write up...and one thing that kind of puzzled me.... light coat of grease... I have had issues before with even a light coat of grease, as time goes on, tends to get a little thick and the hubs don't disengage as easily cause the old grease tends to hold them in place. I have always just dipped the hub body completely in tranny fluid then slid them on. I haven't had any issues to date by doing this...am I the only one doing this or am I looking at a long term issue down the road?
  #59
Old 03-18-2008, 05:38 PM
Krewat's Avatar
BillyBob, Warn even says in there instructions to NOT grease the hubs with anything, they are already coated in something.
Looks like cam break-in lube - very metallic, not much viscosity, but clings to everything.
And not much of it, either.
I did, however, use boat trailer wheel bearing grease, the kind that doesn't mix with water and turn to soup. The blue stuff. Not a lot, just enough around the **** mechanism on the inside of the cover, and over the splines so I could get the thing off again when I wanted to. The splines on the axle, that is.
  #60
Old 03-18-2008, 09:16 PM
BillyBob69's Avatar
...., and over the splines so I could get the thing off again when I wanted to. The splines on the axle, that is.
HA!! And I thought I was the only one doing enuendos today...hehe
2017's on Ebay Rasty1 2017 Super Duty 5 10-04-2016 08:41 PM
37" With No Rubbing? Irish816 Brakes, Steering, Suspension, Tires, & Wheels 1 10-01-2011 06:50 PM
About me and my trucks(the untold story) SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-16-2011 12:04 AM
F350 Aftermarket Mirror Options ? AlienX69 1999 to 2016 Super Duty 9 10-11-2008 11:33 PM
Front mount spare tire carrier lp92chateau 1968-2013 Full Size Vans 6 07-19-2006 03:40 PM
Tags
2002, 4x4, auto, automanual, bronco, conversion, duty, f250, ford, hub, hubs, installing, instruction, manual, sd, super, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
