Auto to Manual Hubs - COMPLETE - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-07-2006, 11:10 AM
cgl cgl is offline
cgl is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by BFR250SD
... I was actually ticked that I wasn't cussing at my truck for once. It didn't give me enough time to stand around, drink a beer, and think of things to hit with a hammer.
I thought that the flying hammer was common procedure... mine always seem to move themselves across the shop somehow
Old 06-07-2006, 11:29 AM
F250Wheels F250Wheels is offline
F250Wheels is starting off with a positive reputation.
Quote:
Originally Posted by TheHouse
Newbie question here.....
What's the advantage to change from the factory auto hubs to the aftermarket manual type?
If I'm not going to cahnge my auto hubs is there something I should watch out for?
Thanks & great site!!!!
Mikey
Your stock hubs are fine,I have 60,000 mile on stock auto hubs. you must keep them clean and relube them every 20,000 miles. And most important USE YOUR FWD AT LEST ONCE A MOUNTH.
Old 06-07-2006, 11:32 AM
ag-ford-4x4's Avatar
ag-ford-4x4 ag-ford-4x4 is offline
ag-ford-4x4 is gaining momentum as a positive member of FTE.
Yeah, im curious too....
So, you cannot activate your 4x4 without getting out of the truck and turning the new hubs???
Old 06-07-2006, 12:16 PM
TheHouse's Avatar
TheHouse TheHouse is offline
TheHouse is starting off with a positive reputation.
So there really is no advantage to changing... It's just personal pref's as to whether or not you trust the auto hubs & like getting out of your truck in the mud, snow etc to manually engage your hubs
Old 06-07-2006, 01:05 PM
Vijay's Avatar
Vijay Vijay is offline
Vijay is gaining momentum as a positive member of FTE.
Thumbs up
Got the Mile Marker Stainless Steel Hubs installed today. These things are stout and they fit very nicely.
Install was extremely easy. A few simple tools and your done. I didn't even have time to finish a beer before they were installed.
Here's the complete write up for anybody that is looking to do them. It's a 1.4 Meg MS Word document.
http://webpages.charter.net/rsilvano/Documents/Super%20Duty%20Automatic%20to%20Manual%20Hub%20Con version.doc
Thanks for writing us the doc; I really appreciate your time and effort. I just saved the instructions copy in my truck folder. One less trip to stealer-ship ! <O</O
Old 06-07-2006, 01:13 PM
BFR250SD's Avatar
BFR250SD BFR250SD is offline
BFR250SD has a good reputation on FTE.BFR250SD has a good reputation on FTE.
You can still activate / deactivate your 4WD with manual hubs; you just have to have the hubs engaged (i.e. like during winter). Just engage the hubs beforehand if you think you will need them.
Then, just turn the switch when you need 4wd. It does not hurt your driveline to drive that way. It will increase gas usage slightly, but won't have any major negative effects on your truck.
The other advantage to manual hubs, is that you have 2WD LOW. Very handy for backing in heavy trailers on hard surfaces. Just leave the hubs unlocked and engage 4WD LOW. No power going to front wheels; all the torque goes to the rear.
Old 06-07-2006, 04:38 PM
dew487 dew487 is offline
dew487 is starting off with a positive reputation.
Reliabilty is the issue. The factory automatic hubs are prone to failure, just when you really need them. In my case, one of the hubs wouldn't unlock. I've been using Warn manuals now for several months and no problems at all.
Old 06-14-2006, 07:43 AM
mach2race mach2race is offline
mach2race is starting off with a positive reputation.
WOw! what a write up!! THanks a million. So my factory hub is F250 hub is held on by a ring. So, I can remove the old hub, without first disassembling it. Do I have to remove the **** and cap, to access the retaining ring? Thanks guys!
Old 06-14-2006, 08:23 AM
ffdemoss ffdemoss is offline
ffdemoss is starting off with a positive reputation.
Should you cap the vacuum port on the knuckle to prevent water and debris from getting inside?
Old 06-14-2006, 08:24 AM
Nevermind...when I opened the doc those words were behind the picture.
Old 06-14-2006, 09:04 AM
BFR250SD's Avatar
Quote:
Just squeeze the two extensions on the snap ring (you'll see them as soon as you look at the area around the hub) with a pair of pliers and it comes right out. Then you should be able to just pull the whole hub assembly right out. If they are sticking a little, it helps if you have another person to gently rock the truck back and forth and it will pop right out.
Old 06-25-2006, 05:38 PM
RougeDoc's Avatar
RougeDoc RougeDoc is offline
RougeDoc is new and has a neutral reputation at this point.
Will this install also work when replacing manual hubs (- the vaccum line plug)?
  #28
Old 06-25-2006, 06:07 PM
BFR250SD's Avatar
Quote:
PM'd you.
  #29
Old 06-25-2006, 10:59 PM
captchas captchas is offline
Guest
captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.
Quote:
carefull rich is a ranger and only a short time home from afganistan it might be some thing very small and very fast at 1 mile.
  #30
Old 06-26-2006, 04:46 AM
BFR250SD's Avatar
Naaaaaaaaah! It'd be a whole lot more fun to use a hammer.
I'm kidding!
2017's on Ebay Rasty1 2017 Super Duty 5 10-04-2016 08:41 PM
37" With No Rubbing? Irish816 Brakes, Steering, Suspension, Tires, & Wheels 1 10-01-2011 06:50 PM
About me and my trucks(the untold story) SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-16-2011 12:04 AM
F350 Aftermarket Mirror Options ? AlienX69 1999 to 2016 Super Duty 9 10-11-2008 11:33 PM
Front mount spare tire carrier lp92chateau 1968-2013 Full Size Vans 6 07-19-2006 03:40 PM
Tags
2002, 4x4, auto, automanual, bronco, conversion, duty, f250, ford, hub, hubs, installing, instruction, manual, sd, super, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
