1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Auto to Manual Hubs - COMPLETE
Old 06-26-2013, 06:58 PM
Rugerfan's Avatar
Rugerfan
Rugerfan is offline
does anyone have a link to this that actually works? hoping to do a auto to manual hub conversion and wanted to review!!!!!
  #167
Old 06-26-2013, 09:12 PM
redford's Avatar
redford
redford is offline
Received 1,562 Likes on 910 Posts
Youtube is your friend.
This is a video on how to change the hubs on the 2004 and earlier trucks. If you have ESOF, just make sure you cap the vacuum lines.
  #168
Old 06-29-2013, 07:58 AM
jayft8's Avatar
jayft8
jayft8 is offline
Step-by-step photo album with captions in my gallery, too if that can help you.
https://www.ford-trucks.com/forums/m...all-10802.html
  #169
Old 05-29-2014, 10:10 AM
kd6mlh's Avatar
kd6mlh
kd6mlh is offline
Warn
I just Picked up a set of Warn hubs for my 2001 f-350 Dual RW truck. I then was reading the warn web site and it said that there hubs will not work in the dual application.
Is this correct?
Have any of you installed a man hub conversion to a Dual RW truck?
  #170
Old 05-29-2014, 01:15 PM
sp5937's Avatar
sp5937
sp5937 is offline
Originally Posted by BFR250SD
Got the Mile Marker Stainless Steel Hubs installed today. These things are stout and they fit very nicely.
Install was extremely easy. A few simple tools and your done. I didn't even have time to finish a beer before they were installed.
Received my MM hubs today, and put them on my 99 F250 SD in less than 5 minutes....took that long because I accidentally put both snap rings on one side before I looked and realized I had two of the spiral-style snap rings also...so, had to remove the first one and put the correct snap ring in place. Then, put the second one on and finished up quickly.
Now I just need some new center caps so they fit flush to the hubs...anyone know what year center caps will fit flush to the MM hubs and look sweet again???
I will purchase a set if anyone has two spares...or can trade mine for them...whatever...am in Wa State...
  #171
Old 05-29-2014, 03:16 PM
sp5937's Avatar
sp5937
sp5937 is offline
Get out in the rain / snow / mud?
Originally Posted by TheHouse
So there really is no advantage to changing... It's just personal pref's as to whether or not you trust the auto hubs & like getting out of your truck in the mud, snow etc to manually engage your hubs
How about just setting the hubs to LOCK before leaving the driveway, then IF you need 4x4 while out in the foul weather, you just simply shift into it and you do not have to get out. It certainly does not heurt anything to run with them locked. Some people LEAVE them locked all the time, tho I do not recommend it. But, when bad weather sets in, I just lock them, then no getting back out when I need it, and I just wait till I get home again to free them up, if I even do it then.
  #172
Old 11-24-2014, 05:08 PM
kepw377's Avatar
kepw377
kepw377 is offline
changing auto hubs to manual.
for some reason I can not get the word message to copy. will some one please email me a copy . thanks kephartron@Hotmail.com
  #173
Old 11-24-2014, 09:58 PM
kd6mlh's Avatar
kd6mlh
kd6mlh is offline
love them
Is this correct?
I finished the install/convention a few month ago, I love them! The only extra work is the on the DRW you have to pull the spacer on the front end to install the hubs. 16 nut on each side over 8 not a big deal to me.
I also used some nice brass plugs (1/4in I think) to seal the back side of the hubs and delete the vacuum input.
  #174
Old 12-31-2015, 01:14 PM
AB1946's Avatar
AB1946
AB1946 is offline
Replaced the OE hubs with mile marker's in 2010 on my 00 F350, got our first snow this week and found out the 4wd didn't work, Took the caps off the lockouts and found the fingers that rotate the hub were all broken off on the passenger side. Anyone know if MM has a replacement kit for these fingers. There is a snap ring that holds them in place, you would think there was a replacement kit for this. Thanks in advance.
  #175
Old 10-26-2019, 08:33 AM
dvcochran's Avatar
dvcochran
dvcochran is offline
Manual Hub Engage/Disengage Movement?
Here's the complete write up for anybody that is looking to do them. It's a 1.4 Meg MS Word document.
EDITTED by krewat:
Super Duty Automatic to Manual Hub Conversion.doc
Old link: NOT WORKING: http://webpages.charter.net/rsilvano/Documents/Super%20Duty%20Automatic%20to%20Manual%20Hub%20Con version.doc
I just found this post. I have had the Warn heavy duty hubs for years. Sometimes it sounds like the drivers side hub does not fully disengage and I will hear a "popping" sound for a while. I have checked and cleaned/greased the hubs and swapped hubs from side to side but the problem stays on the drivers side. Any ideas?
  #176
Old 11-24-2020, 09:51 PM
Christopher Reade's Avatar
Christopher Reade
Christopher Reade is offline
I am wondering why you went with Mile Marker over Warn hubs? Was it mainly due to their price?
Just Strokin
6.7L Power Stroke Diesel
1229
01-28-2024 05:23 PM
SoCalAngler
18
11-12-2017 07:58 PM
DCH614
Ford Truck Parts for Sale
10-23-2016 07:39 AM
Rasty1
2017+ Super Duty
10-04-2016 07:41 PM
HOTRODTONY
02-08-2016 05:07 PM
Quick Reply: Auto to Manual Hubs - COMPLETE
