Carpet
Carpet
Hey Matt
I went with Line - X on the inside of my cab and couldn't be happier. Between my muddy boots and my dog its awesome and I don't have to worry about messing up my carpets.
Just make sure you relocate the ground wiring and high-beam foot switch before you take the truck in. Also, be sure when you take the carpet out to scrape the moulding glue clean.
I had my cab sprayed from the middle of the inside firewall to right under the back window.
Another thing is that I did not have the inside t-case access plate sprayed. If you wanted this done you could probably remove the plate and have it sprayed seperately. Im thinking about this. My truck is a 78' f150 4x4.
Good luck and let us know how it turns out!
Steve
Steve
Carpet
Got mines from J.C.Whitney & CO.
Good quality stuff, lays in real good. Got the molded type.
Always try to purchase the molded type carpets for any vehicle.
The other (carpet that's been cut to length) is horrible
to fit in a vehicle.
Just my .02 CENTS worth.
Dre'
1978 F-150, 460ci(750cfm,Edelbrock Performer,Dynomax Ceramic Coated headers,etc.)Auto-C6,3:70.1 - 9" Posi.
Dre'
