Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Nova Scotia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Nova Scotia Chapter Join Chapter, Leader:
  #1 (permalink)
Old 02-28-2006, 07:14 PM
bossind's Avatar
bossind bossind is offline
Garage is empty, add now
bossind is starting off with a positive reputation.
Hello!!
Whats up folks? Any plans, projects on the go?
  #2 (permalink)
Old 03-01-2006, 05:05 PM
MatthewC's Avatar
MatthewC MatthewC is offline
MatthewC is starting off with a positive reputation.
Take the Bronco to Rocky Road and have them do up my welding so I can get the bugger steet-able. Wanna seafoam it there too.
__________________
So much to repair, so little money....
  #3 (permalink)
Old 03-01-2006, 10:33 PM
bossind's Avatar
Quote:
Oh well we could have done that at the school! Should have gave me a call! I'm doing my quater panels over the march break and a hydroboost brake system.
  #4 (permalink)
Old 03-02-2006, 03:11 PM
Motoshrump Motoshrump is offline
2003 Ford Explorer
Motoshrump is starting off with a positive reputation.
Just finished the exhaust on my 93 F150 2wd 302. Long Tube hedman headers, 2.5" front pipe flowing into a 3" single in single out flowmaster 40 series delta flow. Dumped it out in front of the right rear...........WOW! Sounds great! With the short tail pipe it resembles a mustang H.O. Works even better than it sounds too! Next is going to be the B&M mechanical shift kit (E4OD) and a set of 3:55 gears to replace the old 3:08's. I run 31" off road tires so the jump in gearing is enough to cancel out the effect of the larger tires. Thats all for now.....
  #5 (permalink)
Old 03-04-2006, 11:07 AM
bossind's Avatar
Sounds good! I have a rear diff 8.8 from my 96 bronco with 3.55s in it, could give you a deal on it. I went with 4.10s in my bronco and to make it easy I picked up a 8.8 from the junkyard and rebuilt it with 4.10s and swapped the diff into my bronco when it was done. I also have a set of 3.55s from that diff. Let me know.
  #6 (permalink)
Old 03-06-2006, 04:51 PM
MatthewC's Avatar
Quote:
I may take you up on some help. Mid-late March when the boys are done the welding, I need to install the core support I bought from LMC. Im thinking that I am gonna install a new timing chain while the front end is torn apart.
-Matt
__________________
  #7 (permalink)
Old 03-06-2006, 07:45 PM
bossind's Avatar
Sure bud, just let me know. I have mine in the school right now, I just got back from installing a hydroboost braking system- bit of a job cause I didn't buy a kit so i have to sourse everything. But its getting there, should stop by sometime.
  #8 (permalink)
Old 03-09-2006, 06:36 PM
MatthewC's Avatar
You would'nt happen to know where I can get my hands on a body mount frame hanger would you? The hole on one of mine is rotted out and the mount is dropping through.
-Matt
__________________
  #9 (permalink)
Old 03-09-2006, 09:59 PM
bossind's Avatar
Junk yard, or make a new one.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
