Head gaskets leaking oil?
Makes alot of sense. Do a search and read about it till you drop. It's a known problem on 99 5.4 & 4.6 It is actually not a head gasket problem but a problem with the way the head was machined. To be more specific it was the way the head was removed from the surfacing machine. Replacing the head gasket is not a guarenteed fix and many have reported the leak soon after the repair. A more positiive repair is to replace the head or heads.
