Rear Differential Questions
Hello everybody, I am a new member here and I have some questions about the rear diff. 1998 F-150 4.6 V-8 Automatic 3spd 2wd 140,000 miles
#1. I have never had to work on a truck before so I'm not real familiar with them. (newbie)
#2. How can I tell what size gears/diff are in there ?
#3. Can I swap gears with another F-150 that would be a straight swap without additional modding ?, If so What would those f-150 models be ?
#4. Where can I get the Friction Modifier ?
I did try searching the forums, however I still am not sure of the "fix".
Here's what's up. On the truck after starting to drive 30mph and up I hear this "whining" coming from the rear, it's kind of like a whistle while accelerating.
I am assuming it's the rear diff. The rest of the truck drives perfectly fine.
I'm hoping I don't have to replace the entire diff. I have read that some folks here add some "friction modifier" to theirs and the noise goes away. I did change out the gear oil in the rear diff and it seemed to quiet the noise, but it did not go away, used 75w90 synthetic, I don't think the previous owner ever changed it as it was black and grey and verry stinky, there were no shavings or pieces of anything in the oil. Any help is appreciated.
Hi ViolentB and welcome to the forum
It's important to use the correct oil and friction modifier if it has limited slip but neither will cure the howling noise. Friction modifier will help keep the clutches (if it has limited slip) from chattering during low speed corners.
It sounds to me like you've got bad bearings which isn't uncommon on these trucks.
Does the noise change when you're on and off the throttle or is it just speed related?
On the VIN tag on your door it will have an axle code. If you search in the forum here you'll find info on decoding it to tell you what gears you have and if it has limited slip.
Replacing bearings in the rear end can be a pretty big job with some tools that you might not have access to such as a press and bearing pullers.
I think I'd start by trying to find a good tech to go for a drive with you and give you his opinion.
Noises can be almost impossible to diagnose on here.
JoeVR5
1983 - 2012 Ranger & B-Series
08-08-2011 10:45 AM
Mr. Finch
12-28-2008 08:34 PM
mcne
09-22-2005 07:40 AM
