V10 failure to start
2002, V10, CC, 4X4.
Over the last couple of months my truck occasionally will start and run for about 1-2 seconds then die. It will not start after that until it decides to; starter turns over OK, plenty of battery power. Usually it will start after some period ranging to a 10 min. or so to over night. Last week I had to have it towed (15 miles) to a mechanic and it still would not start. He was working late, so decided to start on my truck and the darn thing started. He could not find anything wrong (no codes popped up).
Question: What the heck is going on? Has anyone had a similar problem?
I am goin to PA next friday and really would like to get back within a week.
when it stops running or will not it cranks no start, that means you have to start checking. one is does it have fuel pressure at the fuel test port on the intake manifold rails that connect the injectors to the intake and fuel system , it looks like a tire pressure valve on the chrome plated tubing rail. "thats the fuel rail"
if not then you have to check for why. at 54k you could very well have a bad fuel filter or a pump starting to go bad. maybe even a failing pump relay. it's really a time for a very good tech to go into it. a trip from where you live to pa. i personly would not till it's 100% running correctly. as it could let you down on the road . then your at some techs who could be a rip off highway one's mercy. have it repaired were you feel safe before the trip starts. and good luck.might just be a clogged fuel filter
An EFI motor that starts and then stalls a second or two later usually isn't building fuel pressure.
The pressure left in the system from the last time it was running is what gets it started, and then it runs out of fuel pressure and dies.
Probably the fuel pump, but could be the fuel pump relay or a bad connection at the fuse or in the wiring.
Two things to try next time it does it.
1) Like rvpuller said, see if it starts when you hit the gas like 1/2 or 1 inch.
2) Bang on the gas tank with a 2x4 or other appropriate "long heavy thing" (somewhat gently). If it immediately starts, it's almost 100% certainly the fuel pump.
I am betting: Fuel filter, clogged fuel pick up screen, weak pump...in that order
Could also be Idle Air Control (IAC) or EGR but usually these faults still let the motor start.
I doubt fuel circuit electrics...they are either good or bad and rarely in between
I bet very low pressure at the Schraeder valve air bleed test port like Charlie pointed out.
Thanks for the info. The mechanic I took it to also thinks the problem is associated with the fuel pump, but once the truck started running he could not find any problem. (tried playing with the accelerator a little, didn't work). I thought about the fuel filter, but once the engine starts it runs smoothly with no problems at all, so I guess it could be the filter but seems to me the fuel flow should be interrupted all the time if it is clogged.
