Do roller rockers fit under stock valve covers?
Pretty much as the title states. I'm looking at buying some aluminum roller tip and roller fulcrum rocker arms. 7/16 stud with poly locks. Will the fit under my stock valve covers from a 1972 motor? If not anyone know of some valve covers that will work that aren't too expensive? Or rocker arm that will fit under my stock valve covers? I'm running hardened push rods and guide plates on C9 heads.
If you buy stud mount roller rockers you need guide plates and hardended push rods, that's what I have. If you buy pedastal mount roller rockers you don't need the guide plates but you can't use these on early heads and are not adjustable. I've always converted my 5.0 mustangs from Pedastal mount to studded rockers with guide plates, much better in my opinion.
Originally Posted by fordtruggy
JEGS sells a set of alluminum tall fordracing valve covers for the 460.They donot go flat on top like the 460 stock covers do,they look like chevy covers.
125.00 for the set.
125.00 for the set.
they don't look like chebbie valve covers I think these are the ones our talking about.
https://www.ford-trucks.com/user_gal...oid=78201&.jpg
Originally Posted by bigsnag
I suppose you do know the differences in the heads required to run pedestal mount vs. stud mount????
Well, I'm not sure what that emoticon is supposed to represent, but if you seriously don't know then here goes. With the pedestal type, they bolt down just like the stock rockers. They are self centering and I'm pretty sure you have to get the right length pushrod as there is no adjustment (maybe you can shim them a little??). The stud mount type require that the heads be machined. Basically, they mill off the surface where the stock rockers bolt down. This makes a flat surface for the guide plates to sit on. Then they also need to be machined to accept studs. Then you slide the rockers over the stud and the locking nut on top is your adjustment.
