Gas Leak under hood next to battery - Ford Truck Enthusiasts Forums
Old 02-27-2006, 09:25 AM
felixr's Avatar
felixr felixr is offline
felixr is starting off with a positive reputation.
You know that canister thingy next to the battery? I forget what its called. . .well im workin on puttin a set of map lights and im under the hood disconnecting the battery and i hear this gurgling or bubbling and a leaking. and i smell gas. im feeling around and one of the lines coming into the canister thingy from behind the engine(i followed it visually) and right next to the fram is covered in what smells like gas mixed with water.
i did not start the truck at all but did put the key to start or run or whatever a few times. and had connected and disconnected the battery a few times if that helps.
what the heck is goin on? thanks guys
btw: i'd say it leaked for about 20-30 seconds and dropped not enough to where it created a puddle but just like a wet mark. . you know, like when you spill oil and clean it up it leaves an impression in the concrete. . . like that. and only within the area of about 10 inches in dia.
Old 03-01-2006, 10:59 PM
felixr's Avatar
33 views and not a single comment?
Old 03-02-2006, 08:57 AM
LoosMaster's Avatar
LoosMaster LoosMaster is offline
LoosMaster is starting off with a positive reputation.
Well, the thingy you're talking about is the fuel vapor canister. As to why you have fuel and water puddling, I'm not sure unless you have a hole in the line near the area that may be sucking air and causing the noise. I've looked at this thread 3 times and have no idea, sorry.
Old 03-02-2006, 09:16 AM
felixr's Avatar
lol, thanks for trying and responding.
Gas smell at start up 01fordeb Expedition & Navigator 3 06-07-2011 02:34 PM
TWO miles per gallon? Bill W 1961 - 1966 F-100 & Larger F-Series Trucks 5 07-20-2010 01:41 AM
At wits end...92 F150 4thfordtk Fuel Injection, Carburetion & Fuel System 9 01-11-2007 07:06 PM
Charcoal Canister Longneck 1987 - 1996 F150 & Larger F-Series Trucks 8 10-02-2003 09:07 AM
What is this part? 88BigGuy 1978 - 1996 Big Bronco 7 01-14-2003 11:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
