Rearend 86 4X4
f150... 8.8inch, possibly 9 inch rear
f250-f350.... ford sterling, possibly dana 60
first rear is what i think ya have, second listed is possible. i've seen 86's with both of them, if i recall, 86 was transition year. no diff in perch width between 2 or 4x4, just make sure gearing matches the front axle otherwise you get to join the tick tick snap club.
not that i'm disagreeing, but how do you know your rearend is about to go? unless you have a good relationship with your junkyard, it'd probably be cheapest to just replace you ring and pinion set. even if you get a cheap one off a u-pull, you'll most likely have to replace other parts (brakes, etc.). i would understand if you wanted to upgrade to a heavier duty axle, but why do you want to replace it right now?
dumptruck denny
02-20-2016 07:48 PM
dyoungen
02-20-2012 09:49 PM
couleeman
12-18-2007 09:33 AM
G Campbell
07-27-2005 08:36 AM
Katmandu2
08-28-2003 10:49 PM
