supercharging a V-10
Old 02-26-2006, 02:10 PM
bmxjtk's Avatar
bmxjtk
bmxjtk is offline
OK. I what more power out of my V-10. I wnat to supercharger it. i have heard that it cant handle the boost, on a stock engine. Is this true? and how much boost can it take? i have found 4 brands that have around 6-10 pounds of boost. i want all it can take safely, with out destoying the engine. can any one help?
Old 02-26-2006, 03:11 PM
BigF350's Avatar
BigF350
BigF350 is offline
For a start - Welcome to FTE!!!
I see no reason why a V10 couldn't handle 6-10lbs of boost. However if you were going for one that makes 10lb of boost I would lower the CR.
Old 02-26-2006, 03:16 PM
bmxjtk's Avatar
bmxjtk
bmxjtk is offline
CR? compretion ratio. how do i lower it.
Old 02-26-2006, 03:20 PM
BigF350's Avatar
BigF350
BigF350 is offline
Yeah, sorry, Compression Ratio.
You can lower it by having thicker head gaskets made. The only reason I suggest this is to prevent pinging, the V10 will still be able to handle the higher cylinder pressures, but whether it will cause pre detonation of not (even with premium) is the main question.
Old 02-26-2006, 09:15 PM
G Lube's Avatar
G Lube
G Lube is offline
Reading the post from the V10 forum, re-gear your truck if you haven't done so. You will get a BIG improvment over what you have in it now. Go with 5.38s and you will be good.
Gary
Old 02-26-2006, 11:04 PM
73mach1's Avatar
73mach1
73mach1 is offline
only if never plan on driving on the hi-way again
Old 02-26-2006, 11:10 PM
G Lube's Avatar
G Lube
G Lube is offline
Mach 1, he is running 42 inch tires. With those size tires, 5.38s will put him close to the 4.30 range which is the sweet spot for the modular engines.
Old 02-27-2006, 12:57 AM
73mach1's Avatar
73mach1
73mach1 is offline
never mind then
Old 09-03-2006, 12:45 AM
holechit's Avatar
holechit
holechit is offline
I've got a whipple installed running about 8lbs of boost at sea level. Also running SCT programmer, Methanol/water injection, and 4.56 gears on 37" tires. Drop me a line and I'll try to help with what I can. I've also put the truck on the dyno. So I have some data too.
98infinity
Modular V10 (6.8l)
15
09-12-2019 07:09 PM
LukeStreeter
Ford Truck Parts for Sale
01-06-2016 11:02 AM
rlauer
10-21-2015 08:01 AM
AltaEx
03-29-2009 10:15 AM
OverEngineer
Modular V10 (6.8l)
03-30-2008 04:28 PM
Quick Reply: supercharging a V-10
