Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-26-2006, 11:33 AM
mcne is starting off with a positive reputation.
Erratic Aftermarket Tachometer
I just installed a Summit Racing 2 1/16 tachometer on my 1987 Ford EFI 300/C-6 that I have owned for about 8 years. All of the wires are soldered and installed correctly per the instructions.
The tach. does work, but the signal is pulsing (it always pulses higher than the actual engine rpm). The higher the rpms the worse the needle jumps around. At idle the needle does not pulse.
What is my problem?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-26-2006, 04:05 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
I would get a voltmeter, and check your power connections when you rev the motor. Make sure you put the meter on the ground wire of the tach, and then check both power wires (red and orange) coming in to make sure it's steady.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 02-27-2006, 08:27 PM
Franklin2 how many volts should I be seeing? 12 volts?
  #4 (permalink)
Old 02-28-2006, 08:11 PM
Franklin2's Avatar
12 volts or possibly a little higher.
__________________
Dave F
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
