1992 F150 Charging Problems - Ford Truck Enthusiasts Forums
Old 02-26-2006, 06:55 AM
digitaldemon digitaldemon is offline
digitaldemon is starting off with a positive reputation.
92 F150 6cyl. Auto OD
Last May I had a new alternator and battery installed, with a 1 year warranty
August I had to take the truck back and have them fix the alt again
<O</O
The other day I noticed a smell of burning insulation (elect.) the truck quit charging and the wires on the bottom plug (two heavy gauge Battery wires and one smaller gauge starter wire) had melted and almost caught the alt. on fire.<O</O
I replaced the alt. as well as the plug and wires
It still will not charge. I have tried everything I know.
The battery is at full charge but only shows about one quarter charge on the gauge
It dies when you pull the negative post off battery while running
I am getting no advance on the gauge when I rev the engine
Old 02-26-2006, 07:41 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 02-26-2006, 08:18 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
When this happens the Fusible Link "J" (14 GA-GRN) opens. On this type (2G) of Alternator you can buy a replaceable bridge with a stud on it and do away with the plug. You can also replace the Alternator with a type 3G from 1993.
This plug is a common failure on a 2G Alternator.
Fusible Link "J" (14 GA-GRN) is at the other end of two heavy gauge Battery wires at the Starter Solenoid on the Battery side.
Here is a diagram of your system.
Old 01-28-2013, 02:41 PM
jross2510 jross2510 is offline
jross2510 is starting off with a positive reputation.
Do you guys still have the diagram of the wiring system from the alternator to the battery? My 1992 ford f150 is doing the same thing as digitaldemon's truck.
Old 01-28-2013, 03:19 PM
subford's Avatar
Should have.
Email me at the email address below in this post and I will see if I can find it.
65 f100 wiring diagram SC65F100 1961 - 1966 F-100 & Larger F-Series Trucks 14 01-14-2013 04:45 PM
Low to no boost, hi EGTs mmccasli 1999 - 2003 7.3L Power Stroke Diesel 10 11-20-2007 08:29 AM
2000 Expedition leaning on the right side jd111404 1997-2006 Expedition & Navigator 7 04-21-2007 12:25 PM
OK fellas...enlighten me please... lil smokey FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 04-17-2007 07:58 PM
61 Unibody headliner questions Corbetts_Auto 1961 - 1966 F-100 & Larger F-Series Trucks 3 02-03-2007 03:19 PM
Tags
1987, 1992, 1999, 460, alternator, charging, e150, econoline, f150, ford, fseries, fusible, issues, link, problems, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
