How can I disable the overspeed warning chime ?
Hi,
first let me introduce myself. My name is Robert and i am from germany. After having a 1984 F150 for some years . . .
http://www.dr-mustang.com/uploads/forums/fox_65.jpg
...I now own a 1990 F250 XLT Lariat since two days.
Its a great truck and i love it.
http://img123.imageshack.us/img123/9888/f2dfr6rk.jpg
But i have one problem with it. When i drive faster than 120 km/h ( approx. 75 mph) a warning chime starts until i go slower. The car runs much faster an in germany its allowed to do so. So please can anyone tell me how to disable that chime.
thank you
Robert
thank you
Robert
Robert:
Is the truck still in Germany?? The picture shows the truck with German license plates.
I suspect that the warning chime was placed on the truck either by the factory or by the German dealer because the tires(original) were not speed rated and anything over 75 MPH sustained would strain the tires.
It wouldnt be a good idea to disable the chime--nor would it be a good idea to drive the truck over 75 MPH for any length of time if the tires are not speed rated.Does this truck have a diesel or gasoline engine?? American domestic gasoline trucks dont have such a chime.
Is your speedometer calibrated in KPH or MPH (the large numbers on the dial)?? Check a wiring diagram of the truck if the truck is an export truck---and you should see where the circuit is for the chime. If the truck is an American domestic truck that was exported to Deutschland--then your authorities may have added the chime and it wouldnt show on a export wiring diagram.
What is it like to drive an American truck in Germany and on the Autobahn anyhow?? What is the price of gasoline in Deutschland now??
What is your rear axle ratio in the 1990?? Look in the driver's doorjam and there will be a sticker and it will have a two character code under the axle catagory---tell us what the code is and that will tell you what axle ratio you have.
Does your truck have a catalytic converter and EGR valve ?? Was it originally an export truck--or did you buy it from an American ??
Nice looking truck!! I bet that you get looks when driving it.And that 84 sure was a clean well cared for truck--you didnt sell it did you??
fox,
the part is called 'selectable RPM controller breakout'.
it is near the chime itself that you can hear when the door is open and the key is in ignition. make it chime and find that.
now follow wires back to a plug, maybe 8" away and unplug that.
that is the rpm controller.
truck may not run with that disconnected.
i would recommend not going over what the tire rating is.
nice looking trucks.
welcome to fte.
quicklook
welcome to fte.
quicklook
quicklook2:
I never heard of a speed chime/RPM controller in this vintage gasoline engine truck.Is this a diesel feature only?? And isnt the speedometer mechanical in the 1990s--and electronic after 91?? Why did Ford install these chimes?? And what years have them?? Is it an export truck requirement??
I suspect that the warning chime was placed on the truck either by the factory or by the German dealer because the tires(original) were not speed rated and anything over 75 MPH sustained would strain the tires. It wouldnt be a good idea to disable the chime--nor would it be a good idea to drive the truck over 75 MPH for any length of time if the tires are not speed rated. American domestic trucks dont have such a chime.
Is your speedometer calibrated in KPH or MPH (the large numbers on the dial)?? Your 90 should have a cable running from the transmission to the speedometer head. The chime is probably between the head and the transmission--or within the head of the speedometer. Check a wiring diagram of the truck if the truck is an export truck---and you should see where the circuit is for the chime. If the truck is an American domestic truck that was exported to Deutshland--then your authorities added the chime and it wouldnt show on a export wiring diagram.
What is it like to drive an American truck in Germany and on the Autobahn anyhow?? What is the price of gasoline in Deutshland now??
the speedometer has the big kmh scale on it.
my 1984 F-150 was not in good condition when i bought it years ago. I did a total restaoration for about two years and brought it to that condition on the pic. I sold it last year to finance my greatest dream . . . a 1970 Mustang Mach 1.
please feel free to go to http://www.fordclub.info there you find on the left some categorys. choose Autos for pictures of the done F 150 and the Mach 1. Or choose Werkstatt to find pics of the F150s restoration.
I hope my english is good enough you understand what i mean.
cu
Robert
Robert:
Your English is excellent. If could write in German as well as you can in English--I would be very proud of myself. Do you speak English as well as you write in English??
Code 39 means that you have a 3.55 to 1 rear axle ratio and that the differential is open--no limited slip. And the axle capacity is 6250 pounds.
You routinely turn 3500 RPMs on the highway in overdrive?? Wow !! Just how fast have you had that truck anyhow?? What type/name brand of tires do you have on that truck--and what speed rating are they??
I will take a look at that website. And gasoline is over 4 dollars per gallon overthere?? You must be a diehard trucker!! You must also be one of the largest privately owned vehicles on the road overthere!!
It's early morning in Deutschland now --isnt it??
Originally Posted by s8whiskey
3500 in overdrive is bad? Im not lying but I push my 93 to a solid 4200 for a long haul to spring hill and back 45 min drive. Ive gotten clocked at 114 once in my truck.
And just how much did that clocking at 114 MPH cost anyhow??
OK, 3500 RPM is FAST - not necessarily a bad thing - just FAST. I know for sure that I wouldn't want to try to haul my truck down in a hurry from 114MPH. Even on my motorcycle hauling down form 100+MPH can cause some real pucker moments. 114MPH up here would definitley cost you your license, put you in a court of law and potentially even a night in jail if you couldn't get a liar fast enough.
Cheers!
Mike
Cheers!
Mike
Cheers!
Mike
Cheers!
Mike
The lucky ones--are those that learn this without killing themselves or some unlucky victim.
Yeah--we just got to love those liars/lawyers--dont we??
