Stuck in first Gear??? - Ford Truck Enthusiasts Forums
Old 04-05-2001, 08:30 AM
Ratsmoker's Avatar
Ratsmoker Ratsmoker is offline
Ratsmoker is starting off with a positive reputation.
I have a 1970 F-100 with a 390 & c6 tranny. If I drop it into first and stomp it I can't get it out of first unless I stop and then it is still hard to get out. If i put it in first and go easy on it and shift to second it shifts fine. A guy I work with who has the same year truck has the same problem. Is there some way to remedy this? I thought it might be linkage but I wd40'd the heck out of it and checked its position in first but it doesn't seem to bind. I really need to have it so I can shift manually because 3500rpm automatic shift points just won't cut it after the motor gets rebuilt to around or purt near as some say 400+ HP. My motor mounts are getting pretty old but they aren't broken. This is my only guess to where the problem lies.
Old 04-05-2001, 04:55 PM
FE427TP FE427TP is offline
FE427TP is starting off with a positive reputation.
If your going to rebuild the engine why not take advantage of the oppurtunity and get the transmission rebuilt with a good shift kit while you are at it? but I'd check the vacuum lines too
Old 04-05-2001, 04:58 PM
Ratsmoker's Avatar
The tranny is getting rebuilt about 5 days after the engine is done. It will have a shift kit and high performance clutch packs but I don't know if that will fix my problem
Old 04-05-2001, 09:49 PM
jkmjustin jkmjustin is offline
jkmjustin is starting off with a positive reputation.
I know the '74 LTD my grandfather had you could floor it and hold it it would not shift out. My dad did a test run after changing carbs on the 460 it hadn't shifted out of 2 gear at 90 when it blew a freeze plug. Sorry couldn't really help.
Old 04-05-2001, 10:11 PM
sweet82 sweet82 is offline
sweet82 is starting off with a positive reputation.
STUCK IN 4 LOW TGSTP 1997 - 2003 F150 6 03-06-2011 11:48 AM
88 B2 4x4 Shifter problems JB B2 owner Bronco II 3 11-29-2009 05:58 PM
High idle and won't shift ResJudicata 1997-2006 Expedition & Navigator 4 01-27-2009 10:26 AM
No Gear Shift erik-the-viking 1999 - 2003 7.3L Power Stroke Diesel 9 01-21-2009 12:54 PM
**Transmission C6** 78FordTruck78 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-31-2008 04:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
