Door Open light
If you have access to a NGS tester, you can read out which switch is bad. Otherwise you can use the process of elimination. I replaced my rear hatch switches, and then found that the driveer's door had failed a second time. These switches are mounted on the latch mechanism, and I have found they fail often.
I had same prob 2001 Excursion v-10 dealer told me about switch in door jam- WD40 it
This happened in Jan--I just looked to see where it was again but couldnt remember--ill try tomm again. If all else fails--call the dealer--he may know off hand.
