How many quarts of transmission fluid? - Ford Truck Enthusiasts Forums
Old 02-23-2006, 08:45 PM
78RangerSuperCa 78RangerSuperCa is offline
78RangerSuperCa is starting off with a positive reputation.
The Haynes manual says 23.5 pints which equals 11.75 quarts for a C^ automatic transmission. That seems like way too much. Can anyone tell me how much it usually takes when changing the fluid and filter? Thanks!
Ty
Old 02-23-2006, 09:59 PM
thesprocket26's Avatar
thesprocket26 thesprocket26 is offline
thesprocket26 is gaining momentum as a positive member of FTE.
Most torque converters take like 6+ full and then 1 for the lines and at least 6 for the pan and such so yeah. I just did a tranny swap on an FMX and it took 14 quarts.
Old 02-23-2006, 10:08 PM
53fatfndr's Avatar
53fatfndr 53fatfndr is offline
53fatfndr is gaining momentum as a positive member of FTE.53fatfndr is gaining momentum as a positive member of FTE.
My C6 with an external cooler takes about 13 quarts. So, your 11.75 quarts for a stock system seems reasonable.
Thanks! It just seemed a little high to me.
Old 02-24-2006, 11:43 AM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
The large amount of fluid assumes you drain the converter and the cooling lines.
Many shops just drop the pan and change only half the fluid. To do it right you have to drain the converter at least and probably the cooler lines.
Good Luck,
Jim Henderson
Old 02-24-2006, 12:04 PM
DaveBowman DaveBowman is offline
DaveBowman is starting off with a positive reputation.
On my 79 Ford's C6 with an add on cooler I can put about 13 quarts in it if I also drained the torque convertor.
How much Transmission Fluid? Highboy74 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-25-2015 11:35 PM
Transmission Fluid Change 99 Ford Expedition 5.4 potter573 1997-2006 Expedition & Navigator 1 11-11-2012 10:18 AM
Torque Converter Drain Plug Steve95 1978 - 1996 Big Bronco 1 03-14-2006 07:57 PM
Transmission Fluid mixing with Engine Oil chmc Explorer, Sport Trac, Mountaineer & Aviator 1 01-31-2004 03:16 PM
how much transmission fluid? bluesky 1997-2006 Expedition & Navigator 3 08-09-2001 04:04 PM
Tags
150, 2001, 2004, 99, c6, f150, f350, fkuid, fluid, fluids, ford, quarts, transmission, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
