4R70 Rebuild advice please
. I have a 1994 F150 2WD with 4R70 trans that I just replaced the 302 with a 347 stroker which should dyno at around 350 hp. The trans has 163,000 miles on it and works fine and has an aftermarket street/strip valve body. Due to the mileage and increased HP/torque I'm worried the trans won't hold up, also leaks from several places. I would like to have it rebuilt before it fails so I can keep the valve body and cooler/lines and such. The truck is a street truck and only occasional hauling. I would like the internals beefed up to withstand at least 400 hp. There's a lot of rebuild kits out there claiming to be the best. Is there one that is deemed superior? Also, I'm thinking it might be a good time to replace the TC. While the truck is not a race truck, it will see a lot of spirited street driving and I would like the new converter to be better suited to that. What stall would should I be looking at?
Thanks in advance, Rick
Going to a high stall converter isn't going to gain you anything with that cam. The powerband on it is published at 1200-5200 RPM. If you *wanted* to go to something "Heavy Duty" you could look at something like https://www.summitracing.com/parts/ape-26550 Which is reportedly a stock stall speed, with beefier internal components. Note, I have no personal knowledge of this brand, or if it's worth a darn. Just what I came up with on a quick search for Heavy Duty converters for a 4R70W.
little_buddha
24
06-02-2012 06:44 AM
saskpwr
05-14-2010 10:45 PM
