1986 ford 4.9L setting timing help needed
Vehicle: 1986 E-350, 4.9L 300 6 Cyl auto trans/ac
New long block.
Doing something wrong, Brought number one piston all the way up to tdc on compression stroke , had notch on harmonic balance pulley at zero, installed distributor with rotar pointing towards number one spark plug wire.
Backfired, moved distributor from full advance to full retard.
please help.
Just installed a new reman long block from Marshall rebuilders.
Can't start the engine, stopped work at 9:00 pm pst.
Looking to get back to work in the morning.
New long block.
please help.
Thanks 390 and this helpful forum
I'll be 62 years old on 4-16-06, and we're helping my 32 year old son get his 1986 E-350 running.
This my first engine pull and install, I bought a 8 ton ram cherry picker, HD engine stand, 20 gallon wash table.
With your help tomorrow I'll complete the install.
thankyou again
thankyou again
hello blueknight44. im also going to drop a new distibutor in my 89 300 six efi saturday. I thought my trouble was fuel. i changed the filter ahead of my high pressure fuel pump . no luck. changed the filter behind it just yesterday and still no luck. my truck fired up for abought 2 sec's then shut off. no fire from my dist.. or its the ign module... anyway just post back how it works out if you will. may need some tips myself.. toyota88... thanks goodluck..
