camshaft position sensor (problem) - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-22-2006, 04:00 PM
funzjb1's Avatar
funzjb1 funzjb1 is offline
funzjb1 is starting off with a positive reputation.
Angry camshaft position sensor (problem)
I have a 96' f-250 PSD. supercab 4x4, I have 177000 mi. My problem is it is eating up the cam position sensors it started sending out a trouble code for this a few days ago. OK here is the bad part this will be the FOURTH one I have put inin the past four years ????????? What could be the problem causing this ??????
Old 02-22-2006, 04:45 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
to be honest there may not be a problem. these truck eat cps's. maybe you need to have the air gap checked but other than that it just part of being a powerstroke owner. one a year is excessive from what i hear but to the best of my knowledge not much you can do about it.
Old 02-22-2006, 05:25 PM
ForemanES's Avatar
ForemanES ForemanES is offline
ForemanES is gaining momentum as a positive member of FTE.ForemanES is gaining momentum as a positive member of FTE.
My CPS lasted 180,000 miles and now I am having issues with it again at 220,000. Has anyone tried this improved blue CPS? http://www.blackclouddieselperforman...54ed35c53d534b
Will it even work on the OBS psd?
Old 02-22-2006, 10:55 PM
cookie88's Avatar
cookie88 cookie88 is online now
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Quote:
Physically damaged, like the sensor is making contact witht the target ring, or they just quit working?
Old 02-23-2006, 07:10 AM
1997F-350's Avatar
1997F-350 1997F-350 is offline
1997F-350 is gaining momentum as a positive member of FTE.1997F-350 is gaining momentum as a positive member of FTE.
i read about a guy a few weeks back who was losing them every ten miles or so. he had a bearing worn on his cam and it was allowing it to walk forward and get to close to the cps messing with the magnet signal. doesnt sound like your case. try a blue and see if it holds up any better.
Old 02-23-2006, 07:33 AM
tjbeggs's Avatar
i am not sure about the blue sensor. check out the thread in the superduty diesel section and see the exodus of people that have since taken theirs back out. not enough is known about what this sensor does to for me to feel safe using it. i have seen conflicting reports on what it does to the timing. one very knowledgable guy did alot of testings (he an IH tech) and found that it retards the timing by a few degrees and some "think" it advances the timing. too much conflict and not enough testing done for me. but yes if you get the correct revision it will work in the OBS.
Old 03-02-2006, 02:30 PM
Lanny Sutton Lanny Sutton is offline
Lanny Sutton is starting off with a positive reputation.
I put one on my '95 Tues.,seems the engine runs smoother and quieter.My MPGs had gotten awful before putting it on and I'm confident it's improved my mileage.The International dealer was about $40. cheaper than Ford.
Lanny
Old 03-02-2006, 02:42 PM
mguttery mguttery is offline
mguttery is starting off with a positive reputation.
My F-350 died on me while I was pulling up to a red light in a turn, what a scare to loose PS then. I suspect the CPS but all I have red in other forums is it is an intermittent problem. When it died, it died and would not restart even the next day. The glow plug will not come on either. Is it possible to ohm out the CPS or check it with a test light?
Old 03-02-2006, 04:25 PM
Scott9345 Scott9345 is offline
Scott9345 is starting off with a positive reputation.
Cool
Just had mine replaced. 2nd one in 20,000 miles 96 F350. But the interesting thing was my truck didn't just die, it went into limp mode speraticly. Hence I did not think it was the CPS, my mechanic read the codes and it was the dastardly CPS
Old 03-02-2006, 04:36 PM
Thanks. I just found the CPS at an International Truck dealership for $101.69, here in Kennesaw GA. As an added plus their parts dept is open until midnight. Ford wanted $202. NAPA, who usually beats the pants off the dealer was $230.
Old 03-02-2006, 05:01 PM
What's the deal with these dealers?The Ford dealer I called sells them for $131.00.What is the excuse for one Ford garage to be $71. higher than another?
Lanny
Old 03-02-2006, 07:53 PM
plowhand's Avatar
plowhand plowhand is offline
Playing in the Dirt
plowhand has a good reputation on FTE.plowhand has a good reputation on FTE.
The hunt for the Almighty Dollar!!!!
Americanism means the virtues of courage, honor, justice, truth, sincerity, and hardihood: the virtues that made America. The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get-rich-quick theory of life.
Theodore Roosevelt
Old 03-03-2006, 12:41 PM
Atlanta metro area, what more can you say!
Old 05-16-2014, 12:48 AM
twister 88 twister 88 is offline
twister 88 is starting off with a positive reputation.
price
Well each ford dealer can charge what aver thay went. I was lookj g for a front rim f350 I called 4 different places and got 4 dif price. I looked at were thay were at and In the richer parts of town the price was higher u try it and u will c. Even lows dose it and i have caught them. Was funny guy just could not back peddel .
Old 05-16-2014, 03:32 AM
Thor'sHammer's Avatar
Thor'sHammer Thor'sHammer is offline
Thor'sHammer has a very good reputation on FTE.Thor'sHammer has a very good reputation on FTE.Thor'sHammer has a very good reputation on FTE.
Eight years bro......
Air Suspension , Height Sensors Emiland Expedition & Navigator 1 01-05-2017 06:24 PM
Electronic fuel throttle control light John Shreves Modular V8 (4.6L, 5.4L) 10 05-11-2016 06:45 PM
Throttle Position sensor on 89 f150 5.0 harryg753 1987 - 1996 F150 & Larger F-Series Trucks 2 02-29-2012 12:21 PM
2001 Escape 4cyl Crankshaft position sensor tdh136 Escape & Escape Hybrid 12 12-18-2010 09:50 PM
92' 4.9L TPS problem Dan92 1987 - 1996 F150 & Larger F-Series Trucks 1 12-10-2010 05:19 PM
Tags
auto, calculator, cam, camshaft, obs, position, psd, sensor, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
