Replacing the radio antenna
Old 02-22-2006, 12:28 PM
dakonthemountain's Avatar
dakonthemountain
dakonthemountain is offline
Talking Replacing the radio antenna
Hey guys,
I just read the post about FM reception and it reminded me that I want replace my factory antenna with a shorter stubby one, as the factory one hits the bottom of my camper. I can't figure out how to get to the mounting inside the fender. The space is really tight and I can't reach it. I am sure I am missing something...Can any of you give me some hints or ideas?
Thanks!
Dak
Old 02-22-2006, 12:59 PM
1975Ford's Avatar
1975Ford
1975Ford is offline
Hey Dakonthemountain, A 1978 - 1979 radio attenea is what your looking for. Pop the chrome cover at the base of the attenea and remove the 4 screws. Pop off the attenea at the back of radio. Then the attenea should pull through. Where the attenea goes through the fire wall, push thru the rubber grommet/attenea thru by pushing in the grommet and pull the attenea cable from outside the truck. Then you can buy different attenea which can screw into the 1978 - 1979 attenea base.
Old 02-22-2006, 02:29 PM
dakonthemountain
Hi 1975Ford,
Thanks for the info! I didn't realize the chrome base would pop off.. I will try it this weekend and let ya know how it went!
Thanks again!
Dak
Old 02-22-2006, 02:38 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
word of advice. replace it with a aftermarket low interference antenna. i replaced mine last year with a 15'' flexable rubber antenna and it has been great. they will run you about 14.00. just go to any kragen store. they will be on the shelf. the hardest part of this job is running the new cable to the radio.
Old 02-22-2006, 02:46 PM
1975Ford's Avatar
1975Ford
1975Ford is offline
Dakonthemountain, before you pull the attenea cable thru the firewall and out the cab, tie a wire to the end of the attenea. Then when you pull the new attenea cable thru, you can tie the wire to it end and it should help in pulling thru the new attenea. Have a great day, later
_______
Buck
Old 06-17-2007, 12:59 PM
bbf150's Avatar
bbf150
bbf150 is offline
mine is the pointed round one-how does this one come off?
Old 06-17-2007, 05:12 PM
73Custom's Avatar
73Custom
73Custom is offline
When I replaced my '73s antenna, I got the mast, base and cable from a '80-'86 F150. It was cheap and looks identical to the '79 style. Plus it has a screw on mast, so most any aftermarket mast will work.
Old 06-17-2007, 05:47 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Most round base antennae have a flat spot on either side of the base for a crescent wrench to tighten and un-screw it.
Old 06-17-2007, 08:05 PM
ford4life69's Avatar
ford4life69
ford4life69 is offline
Mine keeps hitting stuff but that's cuz it's one of them tall cb antennaes that they were putting in'em back then. Wish it still had the original radio and everything to go with it. I connected that antennae to my Cobra and it doesn't work for PPPFFFTTTTTT so my uncle gave me a Lil Will magnetic one for my roof which hits more junk than my original one. I'd like to get one that looks better but I just can't turn loose of something that's original that wasn't everyday.. you know what I mean? This truck was special ordered for a furniture company in New Mexico so I'm sure they used the CB for their delivery drivers back then.. you know.. before cell phones were even invented...
Not a lot of help from me on the how too but ya know how it goes.. women can't ever keep their mouths shut... *shrug*
cowgirlmechanic
Aerostar
29
01-28-2013 03:38 PM
daveman8963
Engine Swaps
06-17-2006 05:40 PM
SnowmanMike
1983 - 2012 Ranger & B-Series
06-09-2006 03:25 PM
johnsonswamp
Offroad & 4x4
36
03-28-2006 04:56 PM
Brians97F250Crew
6.4L Power Stroke Diesel
02-08-2006 03:38 AM
Quick Reply: Replacing the radio antenna
