EEC Power Diode - Ford Truck Enthusiasts Forums
EEC Power Diode
Old 02-21-2006, 02:51 PM
pchristman pchristman is offline
pchristman is gaining momentum as a positive member of FTE.
EEC Power Diode
In the process of trouble-shooting my electrical system (another story), I came across this power diode in the engine compartment fuse box. It appears to be in the circuit that activates the PCM power relay (in the same fuse box). I've always tested diodes by checking the continuity twice, reversing the leads each time. If it works one way but not the other, diode's good. My diode, however, shows overload both ways (that would be infinity on an analog meter).
But, my meter only measures up to a thousand ohms, so anything over that would probably also show up as "OL". How can I tell if this diode is any good?
Old 02-21-2006, 02:59 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Don't know an easy way unless you have another meter. That cheaper meter should be able to check the diode, unless it has only one 1.5v battery in it, and the battery was low. Most diodes need about .7 volts to start conducting.
Old 02-21-2006, 05:04 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
If you turn your key on and PCM Power Relay clicks (energizes) the Diode is good. Its to stop the power to PCM if you hook up jumper cables wrong, at least that is what I think it is for.
subford's Avatar
If you turn your key on and if the PCM Power Relay clicks (energizes) the Diode is good. Its to stop the power to PCM if you hook up jumper cables wrong, at least that is what I think it is for.
Old 02-22-2006, 09:17 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The meter must have a diode test function if it's a digital in order to test diodes and transistors.
The cheapies aren't able to source enough voltage at constant current to forward bias the PN junction.
The diode appears to be there to keep the PCM POWER relay coil from experiencing back EMF from the ignition coil which might cause it to chatter. It will also keep the PCM from receiving power in the event that battery power is reversed.
Steve
Old 02-22-2006, 10:47 AM
Thanks. Diode is good, and my journey continues. It really bugs me to run across something like that and not know what it's there for or what it does, so I wanted to put my mind to rest.
diode needed in TC lockup mod?? carl2591 1999 - 2003 7.3L Power Stroke Diesel 7 02-27-2017 08:59 AM
Resistance of '96 starter diode? Pseudoname333 Aerostar 12 07-29-2016 08:17 PM
Cranks wont start Bansheesandrider 1997 - 2003 F150 1 01-14-2015 07:05 AM
DIY Lighted Number TS Knob In Gauge Pod snakedoc 1999 - 2003 7.3L Power Stroke Diesel 16 10-22-2013 09:18 PM
2001 Expy.no trailer-tow power to running lights BaitGuru 1997-2006 Expedition & Navigator 7 05-12-2010 11:14 AM
Tags
2005, 350, ccm, clicks, diesel, diode, diodes, eec, f250, ford, pcm, power, powerstroke, test, whst
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
