4wd light flashing constantly...help! - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-20-2006, 05:40 PM
showstopper151 showstopper151 is offline
showstopper151 is starting off with a positive reputation.
First off the truck is a 99' Expedition (E.B. 5.4) and the 4wd light comes on and flashes constant until I turn it off and restart it then it does not come back on. I noticed it does it when it is cold, and when I turn the wheel like it is engaging it somehow??? After the truck warms a bit I can restart the motor and all is well but if it is cold out it just does it again. Also I notice the tires are sticking, almost like pushing sideways when I try to turn the wheel in the morning and they kind of clunk a bit causing the 4wd light to come on and flash constantly. Is this coincidence? Thanks for any input. I really hate to pay the high dollar at the dealer so anything you pro's can come up with will be greatly appreciated.
Old 02-20-2006, 05:50 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old 02-20-2006, 07:46 PM
scottspoerry scottspoerry is offline
scottspoerry is starting off with a positive reputation.
Could be Speed Sensor
Could be a bad speed sensor on the transfer case...they will cause flashing 4x4 light.
Old 02-21-2006, 08:58 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Could be several things.
Need to have the codes pulled. You'll need a scanner capable of pulling Ford-specific codes. Don't know if the cheapos will work, but it's worth a stop at AutoZone.
Steve
Old 02-21-2006, 09:30 AM
the4by4freek the4by4freek is offline
the4by4freek is starting off with a positive reputation.
Autozonw cannot pull the codes for your 4WD. You definately have a sensor gone. Only Ford or a good transmission shop can pull the codes from the transfer case sensors. It sounds to me like your hall effect sensors are bad.... there are 2 of them. I hope this helps.
Old 02-21-2006, 04:46 PM
Thank you all for the info. I will get it looked at over at the ford dealer. Hopefully it will not be too expensive.
Old 08-20-2006, 11:38 PM
Johnny60546 Johnny60546 is offline
Johnny60546 is starting off with a positive reputation.
Question Blinking 4x4 light
The 4x4 dashlight on my 99 xlt w/79000 just started flashing tonight(Sunday 8-20). It shifts into 4h and 4l just fine, but in AWD the dash light blinks... It doesn't exhibit any of the symptoms as noted in previous posts... She drives fine, and except for the wipers coming on when I open the drivers window and the rear wiper only working when it's NOT raining, she has served me well... I searched posts here at FTE and I looked in the original owners manual but to no avail... Of course, I might just be not that smart and missed them... I wish my OD light was blinking... I would have solved that an hour ago...
I also have a recall notice for a speed control deactivation switch... Possibly related???
Old 08-12-2012, 09:54 AM
Countryfied Countryfied is offline
Countryfied is starting off with a positive reputation.
Does anyone know what the ohms are supposed to be on transfer case sensors? would like to test before buying,also the relay switches as well in the dash what they should read ? I've been trying to locate the transmission sensor but to no avail ( I must be blind) is it on this truck? already tested sensor on rear diff. thanks to info here thats fine 4x4 lights flashing got codes P1837 (transfer case sensor ) and C1107 this is on a 1999 navigator 4x4 5.4 any insite on this would be appreciated ,It feels like its 4wd until I get to 30mph then 4x4 light starts flashing I did just have a wheel bearing replaced on front drivers side but flashing was there before that and odometer is flashing but I think I seen the fix for that I have not done the odometer thing yet Thanks (This site has tons of info so glad I found it !
4wd won't engage when cold. alduane Ranger & B-Series 20 08-04-2016 07:57 AM
Hazard Lights flashing when truck is off devongarver 6.2L V8 9 02-09-2016 06:52 AM
No 4wd, and won't switch back. The2003Excursion 1997-2006 Expedition & Navigator 3 01-28-2015 02:47 AM
1979 ford f150 custom Superman2808 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-02-2014 12:38 AM
96 Explorer 4wd/4wdLo lights blinking ARTURO TOSCANO Explorer, Sport Trac, Mountaineer & Aviator 5 08-19-2002 12:43 PM
Tags
02, 1997, 2004, 4wd, 4x4, blinking, blinks, constantly, expedition, f350, flashes, flashing, ford, light, navigator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
