Newest auto trans for 460
Old 02-20-2006, 08:34 AM
JWILL460's Avatar
JWILL460
JWILL460 is offline
Howdy. Im wondering what the newest auto overdriver trans there is for the 460 block. My 79 F-150 has a C6/NP205 combo right now, I would like to find an overdrive auto for it. Anyone know if anyone makes an adapter kit for a newer 4spd or maybe even 5spd to the 460 blocks?
Jwill
Central Iowa
Old 02-20-2006, 06:13 PM
Casey's Avatar
Casey
Casey is offline
The only auto overdrive that will bolt to a 460 is the E4OD.
Old 02-20-2006, 06:59 PM
RTM's Avatar
RTM
RTM is offline
The E40D needs a computer to control it. The only 5-speed is the manual ZF. Of course these are for Ford pieces that do not require adapters.
Old 02-20-2006, 09:25 PM
JWILL460's Avatar
JWILL460
JWILL460 is offline
Well... Looks like I'm going to have to keep the C6. Are there any overdrive units like a gear splitter for a manual trans out there?
Jwill
Central Iowa
Old 02-23-2006, 08:14 AM
scottolan's Avatar
scottolan
scottolan is offline
You can run the E4OD without a computer by using the Baumannator TCS shift controller from Baumann Engineering.. it retails for $425
www.becontrols.com
Direct link http://www.becontrols.com/products/products.htm
The Baumannator TCS can be used to retrofit electronic transmissions to earlier vehicles or can be fitted to applications that originally used electronic transmissions. This system will provide complete transmission tunability via a PC or laptop computer. The versatility and features provided by this system expand the capabilities of automatic transmissions to a new level, rendering older, non-electronic transmissions obsolete. Utilizing performance oriented transmission control strategies, the Baumannator TCS provides much better performance and durability than OEM electronics, while allowing excellent drivability.
Old 02-23-2006, 08:16 AM
scottolan's Avatar
scottolan
As far as converting to 5 speed.. go to www.corral.net/forums and go to the BB forums.. they have several guys on there running 5 speeds...
jwill8957
05-23-2011 09:55 AM
JWILL460
Virginia Chapter
07-30-2007 02:56 PM
JWILL460
Iowa Chapter
07-16-2007 11:27 AM
JWILL460
1999 to 2016 Super Duty
15
01-21-2007 10:43 PM
JWILL460
17
02-25-2006 01:03 AM
Quick Reply: Newest auto trans for 460
